12.7 boost pressure sensor connector
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by GliderKitTrucker, Dec 1, 2020.
  1. GliderKitTrucker
    GliderKitTrucker Light Load Member
    50
    36
    Dec 28, 2019
    Anybody know where I can find a connector like this? On the connector it says Delphi is all I can read. Is this something parr’s stores carry?
    Rideandrepair Thanks this.
  3. Claytonbigsby
    Claytonbigsby Bobtail Member
    46
    112
    Mar 31, 2019
    FE65B629-9EA4-4BFE-B60C-DCCF691483EC.jpeg Dealership may have a repair harness end although they were no help on a harness end for me recently. I ended up lopping OEM end off and going to Auto Value for them to match up a replacement for a KW.
  4. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    That is a metri pack connector. A Detroit dealer should be able to help you with a repair end.
  5. Rideandrepair
    17,548
    56,852
    Aug 8, 2015
    I’ve heard it’s the same connector for a mid 80s GM boost sensor. With the right crimping tool, and new ends, you can repair it. Maybe crimp and solder, without the “special” crimper.
  6. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    You can buy the connector from Freightliner or a heavy duty truck parts place. They give you ll the the pieces. I have done it several times
