12 volt cooler=ecu, starter failure?
Discussion in 'Volvo Forum' started by 20340, Mar 5, 2019.
  1. 20340
    20340 Bobtail Member
    7
    Mar 5, 2019
    Can a 12-volt cooler (plugged into a cigarette plug outlet) cause an ecu or starter failure?
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    i wouldnt thk so
  4. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    7
    Mar 5, 2019
    A Volvo service writer insists it was the cooler and not the battery terminals. First for the ECU, then for the starter. I'm in the Twilight Zone here!
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    The low voltage disconnect should have kicked in.
    Dave_in_AZ Thanks this.
  7. Dave_in_AZ
    423,519
    Which Volvo are you at?
  8. 20340
    7
    Mar 5, 2019
    New Castle DE.
  9. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    If you leave the cooler going on batteries until they drain to less than a particular voltage available, it will brick everything in that truck. No start. Don't be doing that.
  10. 20340
    7
    Mar 5, 2019
    That's not it. I just got unloaded, had 13+ volts. No start. ECU failed as I drove down the road. He's telling my boss the cooler caused this stuff with full batteries--believe it or not.
  11. 20340
    7
    Mar 5, 2019
    After they "fixed" the ECU, issue started recurring. I found loose battery terminals. They just stole my cooler and never even checked the terminals!
    25(2)+2 and Dave_in_AZ Thank this.
