12v cooler plugged in
Discussion in 'Questions From New Drivers' started by 4noReason, Jun 1, 2013.
  1. 4noReason
    4noReason Road Train Member
    2,392
    752
    Nov 29, 2012
    If I leave it plugged even with truck off will it burn out the battery
  3. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    Just overnight it shouldn't if you have decent batteries. Leave it plugged in over a weekend and yes it will drain them.
    dannythetrucker Thanks this.
  4. Numb
    Numb Crusty Curmudgeon
    4,310
    10,231
    Jan 30, 2012
    Charlotte, N.Carolina
    over night, no. over the weekend, maybe.
    depends on how many and what condition your batteries are in
  5. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    Will the batteries on a flashlight burn out if you leave it on?
  6. drozzer69
    drozzer69 Road Train Member
    1,206
    1,143
    Oct 20, 2012
    Spring, TX
    Same as above. over night you should be ok. Weekends, I wouldn't. When I was with Knight, they would only put 3 batteries in the Volvos. They would constantly drain esaily. Couldn't even run the bunk heater in them for more than 4 hours. The Pete I had, had 4 batts in it. It lasted a lot longer.
  7. Vito
    Vito Heavy Load Member
    878
    950
    Jun 4, 2012
    North Carolina
    If you got a low voltage disconnect in your truck it will shut everything down before you drain the batteries so low that you won't be able to start your truck. Mine beeps at me when the batteries get low. The cooler really does use up the batteries but if you run long milage each day you'll be OK for about 18 hours with 4 batteries (in decent shape). But if you're leaving it plugged in all the time and only running a few hundred miles or doing a 34 reset you'll be getting to the point where the LVD will kick in.
    25(2)+2 and sherlock510 Thank this.
  8. sherlock510
    sherlock510 Road Train Member
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    Vito pretty much covered all of the bases.
    Unless i use my microwave the dorm fridge is never unplugged.
    Of course, it's all plugged into the inverter, i dont trust the 12 volt appliances.
    When i roll daily, all is well. If i sit for a day straight the batteries suffer for sure.
    Just keep an eye on your voltage and you'll be fine.
  9. CbarM
    CbarM Heavy Load Member
    894
    247
    Jan 17, 2011
    Irvine, AB
    I think you need descent batteries. Wimpy batteries will not do good. I have 4 brand new 1100 CCA batteries n I leave my 12V Coleman cooler plugged in all the time 24/7. When I am home for 4 days I leave it plugged in n my truck still starts fine after sitting for 4 days...
    25(2)+2 Thanks this.
  10. jbee
    jbee Medium Load Member
    664
    619
    Jun 3, 2011
    NC
    Add to the fact that most 12v coolers are not designed to run 24/7. Mine runs while I'm driving. I leave it on until I hit the bunk and then unplug it. Everything stays cool and when i get up, I plug it back in. Had it for over a year now with no problems.
    Buckeye91 and BlueSparrow Thank this.
