13 speed shift pattern confusion, how did I miss this?
Discussion in 'Ask An Owner Operator' started by georemo, Apr 16, 2021.
  1. georemo
    georemo Light Load Member
    74
    65
    Mar 28, 2020
    I picked up a truck with a 13 speed, no shift pattern in the truck or on the shifter, the door sticker says it's an RTLO-16913a which has a pattern like this '-|-| , I've alway driven it that way and never realized that there was another gear right under reverse like this |-|-| which is a characteristic of RTO-6613 , so what's going on here? this truck is 15 model and before I bought it it was part of a 300+ fleet that dumps trucks before 500k so I don't think the transmission was swapped.
    77fib77 Thanks this.
  3. Ridgeline
    22,719
    123,169
  4. rbrtwbstr
    rbrtwbstr Road Train Member
    3,400
    7,936
    Jul 11, 2012
    in the bush somewhere
    That's low, or granny gear. For pulling out on hills with heavy loads.
    I've heard it called a cheater gear also. According to some, you can use that gear in high range also. Others will say absolutely do not use it in high range. I've never tried it myself, others have told me it's handy at times.
    I always figured that if Eaton Fuller doesn't recommend it, it probably isn't a good idea. Hence the reason on the shift pattern sticker it only shows that gear as LO.
  5. 201
    201 Road Train Member
    12,763
    26,260
    Apr 16, 2014
    high plains colorado
    That be the "mystery gear". It eliminates going to the low side, and I used it all the time. The reason they don't recommend using it, it eliminates reverse gear clash, but it's a gear like any other.. I used it all the time.
    77fib77, Vampire, Coffey and 1 other person Thank this.
  6. georemo
    74
    65
    Mar 28, 2020
    That makes sense now, I've actually used it in both high and low range just to see what geat it was I shifted into it from 4th gear as soon as I switched to high range, and it felt just like you would shift from 5th to 6th in a 10 speed, and it shifted as normal so I assume it's just a crawler between 4th and 5th in high range and a super slow crawler before 1st gear in low range
    Vampire and Rideandrepair Thank this.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    I've only done it once by accident. Not sure how true it is but I've heard the gear is weak??
    okiedokie and Rideandrepair Thank this.
  8. 201
    12,763
    26,260
    Apr 16, 2014
    Nah, a gear is a gear. Actually, using 1st low range, makes up the "13". Ridgelines post is confusing, and if L wasn't used, it would be a 12 speed.
  9. Allow Me.
    10,766
    12,579
    May 28, 2009
    Rancho Mirage, Ca.
    yeah we called it a "secret" gear, and it is a fully certified, bonafied gear. By the time you're in 5th, you don't need a lower gear, kinda' like a half gear. Now, back to trying to figure out what these un-marked toggle switches are ! Right ?
  10. 201
    12,763
    26,260
    Apr 16, 2014
    Don't forget, 3 in reverse too, if you dare,,,:eek: at least the old ones, you could split reverse.
  11. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Dear lord, ive used high range reverse and the truck liked it better than the driver did, 3rd gear reverse seems like it wouldnt go slower than 35 mph, cause high reverse by the time the clutch was out of the way was easily 20 mph no throttle
    Vampire, 201 and Roberts450 Thank this.
