13sp Transmission
Discussion in 'Ask An Owner Operator' started by risen75, Jul 8, 2011.
  1. risen75
    risen75 Bobtail Member
    25
    7
    Dec 30, 2009
    Ok guys...
    I'm looking at a truck.. it's W900.. it's got a 13sp in it.. and the guy says that the sync rolls are shot so it makes a grinding noise when shifting. I haven't seen the truck in person yet or driven it, but, would that be something that should be a deal breaker on buying it? (aka $3000 or more to repair)
    For the price of the truck, if it's under a $3000 repair, i think it would be worth it, however if it would most likely be more than that........
  3. Diesel Dave
    9,630
    32,493
    Jan 20, 2010
    Hesperia, Ca.
    Don't forget the clutch. If your going to R/R the trans might as well do the clutch and rear main seal. Clutch depends on what size and torque rating but add another $800.00 to your $3000.00. Your usually better off getting an exchange trans, but get NEW clutch. Out the door your looking anywhere from $4000.00 to $5000.00. And btw, I recommend you look for a Transmission/Differential shop, not a dealer or a general shop.
    BigJohn54 Thanks this.
  4. jbatmick
    jbatmick Road Train Member
    2,200
    2,510
    Dec 1, 2009
    hastings, Fl
    You can swap them out with a re-man w/ warranty for a little more than 3 grand if you shop around,consider possible new clutch if you have it apart.
