Any truth to the rumor that one should NOT drive for extended periods of time on the low side of the splitter in high gear (overdrive)?
And, if NOT, why?
18 speed
Discussion in 'Trucks [ Eighteen Wheelers ]' started by GRAYMATTERS, Jun 5, 2009.
Page 1 of 5
No truth to that rumor at all. If your transmission is an RTLO the low side of the high gear is an .86 overdrive anyway. The high side should be a .73. 7th and high is the direct or 1.
GRAYMATTERS Thanks this. -
Thanks grizzly.
I thought I read or heard somewhere that it wasn't a good idea to use that gear for extended periods because of weaker components on the low side of the splitter. Heat was also a concern. But, it just didn't make any sense to me.
Come to think about it, it might have been a kenworth salesman that told me that. I think he said it should only be used to transition into the .73 gear.
Hope he was wrong !!
Hope you are right. -
Hello Graymatters: I dont know about the technical end of the transmission, but i have always driven 18 speeds in the gear of my choice for as long as i wanted and have never known of it being a problem.
The 18 is a great transmission, especially if you do heavyhaul. It is nice to be able to split the low gears getting load rolling. -
Its a manual trans, you can drive it around in any gear you want. I've got the 13 spd in mine which has all the same top gears and I run it around in 8th gear direct, have been for about two years now. No problems. I can even get into overdrive until I'm doing about 70mph.
Thanks for the responses.
I otta know better than listen to a salesman. Ya can always count on 'em to steer ya in the right direction....... ya right !!!! The only gears that were suspect, were the ones in his head.
I can see that .86 overdrive gear comin' in real handy. (fuel economy) -
What are your opinions "overall" about the 18 speed?
It seems to me, the more "choice", the better.
That low reverse (15.06) might be worth the "price-of-admission", all by itself.
Come on, don't be shy, let me know what ya think about this "Tranny", (and i ain't talkin' about my uncle).... lmfao -
I run mine in 17th all the time with no problems. The 18 spd has the lowest 1st gear you can get
Hello again Graymatters: As i said before, hauling heavy, an 18 cant be beat. It is nice to be able to have the half gears on the low side getting the load rolling. My transmission has been worked hard (in my opinion) and it has taking the beating so far. I would never own anything else.
If running around empty or with light loads, the gears can be skipped. Drive it like a 9 speed or whatever combination desired. Just split the last couple of gears if more comfortable. Do whatever, that is the beauty of an 18.GRAYMATTERS Thanks this. -
I can't say I've ever had a need or desire for an 18spd. I get the choice thing but I've had most transmissions available and hauled fairly heavy (around 120k) and never had anytime where I wish I could split the lower gears. The truck I drive most of the time is a 13spd with 3:36 gears and big wheels and tires and I never even use low unless I'm just creeping along a gravel drive trying to keep the dust to a minimum. I had a 15spd before and NEVER split the lower gears. I also have a 10spd and hate not being able to split the higher ones, good thing I don't drive that truck. Just a question but how heavy is so heavy you need to shift 12 times before the trailer makes it through the traffic light, maybe a coal truck in WV?
Just a question not trying to hi-jack a thread or pick on anyone.
Page 1 of 5
