19 international ABS module, Eaton code 22
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CrimsonPatriot, Jul 27, 2021.
  1. CrimsonPatriot
    CrimsonPatriot Bobtail Member
    13
    Jan 25, 2021
    Where is ABS module on a 2019 international lt 625. Getting active fault code 22 FMI 14. Troubleshooting steps I’m getting say repair ABS module iaw OEM guidelines but can’t find it. Is that code normally something the module needs to just be replaced or is there a “typical problem” that causes it that y’all might have had.
  3. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    What is the SPN #
    The abs module is under/behind the fuse panel
    CrimsonPatriot Thanks this.
  4. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    That’s a code for your hill start aid. Are all the switches in the centre switch packs working properly?
    CrimsonPatriot and flood Thank this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,767
    9,188
    Jul 12, 2017
    Or
    Eaton FAult code 22 is CAN fault code for ABS. This logs in the TCM every time an ABS event is active.
    Get hooked up with Bendix Pro or Acom
    CrimsonPatriot and spsauerland Thank this.
