20k steer axle
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by SL3406, Apr 16, 2024.
  1. SL3406
    SL3406 Medium Load Member
    551
    1,502
    Jan 10, 2011
    Oklahoma
    I recently bought a 2006 Peterbilt 357 equipped with a 20k steer axle. Single box with a assist cylinder on the
    passenger side. 40 acres doesn't seem to be quite enough to turn this thing around. I was wondering if
    replacing the axle with a later style wide track axle would help? The tag on the axle says Westport Axle Corp.
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,013
    2,085
    Dec 15, 2021
    It might have some stops on it you can adjust or take off and get a sharper turn radius,make sure your tires don't hit the frame when turning all the way if you take them off.
    BoxCarKidd Thanks this.
  4. SL3406
    551
    1,502
    Jan 10, 2011
    Oklahoma
    The stops were already turned in as far as they would go. I took them completely off, but it didn't seem to help much. Nothing gets close to touching with no stops.
  5. dirthaller
    dirthaller Road Train Member
    1,126
    13,413
    Sep 22, 2011
    Coloratah
    In’99 my buddy speced out and purchased a new 379 with the standard track setup (same as yours with the hydraulic assist). He was adamant about having a TRW steering gear instead of a Sheppard. That 260” wheelbase truck turned pretty dang sharp. I’m not sure if the gear itself had alot to do with it or not.
    I had a 230” 379 with a Sheppard and a 260” 379 with a TRW. I slip seated these two at the same time.The longer truck turned sharper (2002 and 2003 year models respectively).
    When I speced out my new 389 in 2013, I was adamant about a TRW steering gear. They wouldn’t let me have it and ended up with a Sheppard. My 389 has the wide track front axle and it turns impressive sharp.
    All these aforementioned trucks had the bumpstops adjusted past the factory settings ( my 389 tires actually hit the gear/pitman arm if I lean too hard on it).
    If you have a Sheppard on a standard track, you might have the same problem as my 2002 379.
    My buddy’s 379 is the only aforementioned truck that has the 20k hydraulic assist.
    SL3406 Thanks this.
  6. W923
    W923 Road Train Member
    1,419
    4,387
    Feb 28, 2022
    So are you running out of travel on the cylinder or the gear…usually with stops removed something hits pretty good
    I assume you have at least 385 tires maybe with 315s nothing would hit
    SL3406 Thanks this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    This stretched day cab will not make a u turn from one side of a 4 lane divided state road to the other. That is not a problem because we are not allowed to do that anyway, right. I bought it this way and just learned how to drive it.
    It is a set forward axle. The set back axles turn a lot shorter turning radius.
    Most times KIMG0159 (2).jpg I tried doing things like you are taking about I ran into problems. Springs are different width, spring hanger off set is different, Neither of the drag links will work etc. Think long before you jump into swapping parts around.
    SL3406 and W923 Thank this.
  8. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Shoot a pic of the profile of truck, do you have the forward or rearward axle version, that will change a lot more than you may think in your perception of how it turns. Ive driven forward and rearward steer axles on both petes and kws amd the rearward steer ALWAYS *seems* to turn tighter than the forward steer even if the wheelbase on the forward is shorter
    SL3406 and BoxCarKidd Thank this.
  9. SL3406
    551
    1,502
    Jan 10, 2011
    Oklahoma
    It has 315's, 245 wheelbase, set forward axle. It's a 10 wheeler dump truck with a 17' box. I thought it was the cylinder running out of travel too, so I unhooked the cylinder from the knuckle, and turned it lock to lock sitting in the shop.
    Just visually, there didn't seem to be a difference in how far it turned. Most of what I do is residential deliveries, and this truck simply won't do what I need to do, so learning to live with it won't be a good solution.
  10. W923
    1,419
    4,387
    Feb 28, 2022
    With the wheels pointing straight ahead take a picture of the pitman arm and drag link from the side if possible.
    If the box doesn’t have enough travel you might be able to put a longer pitman arm on…I did this on a ford with 20k from and a steering box on both sides
    skallagrime, BoxCarKidd and SL3406 Thank this.
  11. SL3406
    551
    1,502
    Jan 10, 2011
    Oklahoma
    That's an interesting idea. I will try to get a pic.
