22 4900 wiring question.
Discussion in 'Western Star Forum' started by Hammer166, Apr 26, 2023.
  1. Hammer166
    7,605
    27,781
    Aug 18, 2007
    ~8600+' and loving it!
    So the secondary trailer circuit is dropping to ~10 volts with any load, but here's the crazy part: the affected lights will go to full brightness when either turn signal flashes. But not even a flicker if the turn signal is on and the markers off.
    So my question, do the trailer circuits go through the body controller? I can't wrap my head around what else could cause this. I haven't had time to chase the line from the 7 way to the firewall, I just jumpered black and brown together for now, and I've got full brightness again.
    I did have a license light bulb go to 0 ohms a couple weeks ago, it was on that circuit. It wasn't popping the breaker, but it did bring the ground up enough to start dimming the markers. So I'm thinking that must have weakened something in the circuit (I did check all of the fixtures, all good there.)
    D.Tibbitt and Oxbow Thank this.
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Pull all relays and fuses from SAM chassis module under hood, driver side firewall, and check for corrosion on legs.
    D.Tibbitt, Oxbow and Hammer166 Thank this.
  4. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    Sounds like a bad ground
    Lights will come on from voltage finding an alternative path to ground
  5. Oxbow
    Oxbow Road Train Member
    13,649
    141,452
    Nov 24, 2015
    That was my first thought, but when he jumped the brown to the black the issue was resolved, so that leaves me to beleive that it is not a ground problem on the trailer anyway. I'll be curious to here the solution.
    D.Tibbitt and Hammer166 Thank this.
  6. Hammer166
    7,605
    27,781
    Aug 18, 2007
    Yeah, only the turn signals affected the marker circuit, not the brake or taillights. When I can, I think I'll start at the firewall before trying to trace the wire from the back of the frame forward.
  7. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    Have you hooked up to a different trailer yet? That’s the first thing I’d do.
  8. Hammer166
    7,605
    27,781
    Aug 18, 2007
    It happens without the trailer, too. Haven't had time to dig further, yet. But even just the 5 top front lights and the 2 side markers pulled it way down.
    And of course, being a carhauler, another trailer is a bit tough. 3' light cord eliminates a lot of options. LOL
    Oxbow Thanks this.
