24.5" vs. 22.5"
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Duliz, Apr 12, 2008.
  1. Duliz
    Duliz Bobtail Member
    31
    McAllen, TX
    I was wondering what are the pros and cons of a 24.5" wheel over a 22.5"? Also, how can you identify a virgin tire from a recap? and should I stay away from recap tires??
    Thanks guys
  3. MACK E-6
    49,989
    237,923
    Well, it's takes less torque to turn the larger wheel, just like on a bicycle a bigger gear is easier to turn than a small one. You may lose a little speed though.
    Also, if you're trailer trucking, 24's may make full cube van trailers too tall for you.
    If you look closely, the seam on a recap may be visible.
    The only thing I would definetly avoid is retreads on your steering axle.
  4. broncrider
    broncrider Road Train Member
    look for a branded # on the casing
    i pretty sure recap's are illegal on the steers, unless it is an intrastate truck (montana for instance), but even then i suggest to take macks advice on them
    22's are better for economy, 24's for top speed, 24 hipro's just look cool...lol
    darnitt, how do you multi-qoute one post??
    thanks fer showing us that mack....lol
  5. MACK E-6
    49,989
    237,923
    Now look, you went and pulled an Aftershock. I have to fix yours now.
    You have to type this--> [ q u o t e ], before the section of someone else's post you want to reply to, and you have to type this--> [ / q u o t e ], at the end of it.
    When responding to individual points within one person's post, you may have to do that several times.
  6. Rockatansky
    Rockatansky Bobtail Member
    40
    Feb 23, 2008
    Anywhere, USA
    Respectfully MACK, you got that backwards.
    All else being equal, smaller tires need less torque to get going and accelerate quicker than larger ones.
    ETA: Smaller tires also weigh less and react to bumps in the road faster.
    Bigger tires will have a higher top speed and more ground clearance for the axles and frame.
  7. MACK E-6
    49,989
    237,923
    Than why is it that the lower gears on a bicycle are larger than the higher ones, and are easier to pedal? Wouldn't the same principle apply to wheels and tires?
  8. Rockatansky
    40
    Feb 23, 2008
    Anywhere, USA
    No.
    Because the fulcrum point (the place where force is applied to the tire) on bike gears is outside the wheel's center.
    On a axle driven wheel the fulcrum point is the center of the axle.(roughly speaking, not technically correct)
    Which is easier to roll by hand?
    A tire rolled by the center or one rolled by the tread?
    Bigger tires act as a gear reducer (numerically smaller number).
    The advantage of bigger tires is that they have a larger outer diameter, covering more ground per rotation.
    Pedal bikes usually don't have suspension either, so unsprung weight of a larger tire is not a factor in handling over bumps.
    Which is a whole other can of worms.
    mgrantes Thanks this.
  9. 25(2)+2
    18,759
    45,962
    Sep 18, 2006
    the road less travelled
    I drive both, and I prefer 24.5s because they ride better over rough roads, 11 R 22.5s are roughly the same height as 24.5 LPs. The truck I normally drive has 22.5 Low Profile, naturally.
    For heavy load situations, the 11R tires will have a higher load rating, and you see them on the heavy haulers, with 46 K and 52 K tandem axles.
  10. dadderich
    dadderich Bobtail Member
    44
    21
    Dec 20, 2009
    22.5 will get better fuel mileage. Recapps are fine as long as you keep air pressure checked regularly. I've ran them without any problems, never on steer axle.
  11. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    It will depend on your axle ratios and the speed you want to cruise at. The bigger size will give you less tire revolutions per mile, giving you lower engine rpms, and maybe better fuel mileage, but the lower rpms might make things worse if you get to a hill and have to downshift.
    Tire sizes also have different weight capacities. A 11R24.5 steer has a higher rating that a low profile 24.5.
