280" Wheelbase with 53' stepdeck?
Discussion in 'Canadian Truckers Forum' started by Centex, May 11, 2019.
  1. Centex
    Centex Bobtail Member
    7
    Austin, Texas
    Sorry if this is a doubled up post as I can't find original but is it possible to run Western CA ( MB and west ) ' long?with a 280" WB and 53' SD being 76.5"
  3. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    The short answer is, no.
    Start reading at Amendment 9 on page 6: https://comt.ca/english/programs/trucking/MOU 2019.pdf
    Tractor wheelbase: 280" (7.112 m)
    Maximum trailer wheelbase: 11.87 m (38.95')
    Maximum overall: 23 m (75.46')​
    You'll have to check each province individually to see if you can permit it.
  4. blade
    blade Heavy Load Member
    881
    647
    Jan 30, 2009
    Some where, Mo
    I’m no expert heck don’t even go that far north but can’t you get a permit??? To run with if you have a long wheel base and long trailer??
  5. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    I dont promise it hasn't changed since i last ran up there but you used to be able to get a permit
    blade Thanks this.
  6. liner
    liner Medium Load Member
    477
    685
    Mar 15, 2008
    ontario
    Slide your fifth wheel ahead to get to 75 ft and your legal Canada wide.
  7. spyder7723
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    He won't get under 75 by moving the fifth wheel.
  8. liner
    477
    685
    Mar 15, 2008
    ontario
    He should be able to get under75 ft.My WB is 284 and I can still get under 75ft with a 53 ft trailer by sliding my fifth wheel ahead about 18 inches.
  9. spyder7723
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    I dont see how. Im nearly 72 ft with a 48. I can slide the fifth wheel up some, but not 2 feet without the trailer getting into the headache rack during turns.
  10. Centex
    7
    Austin, Texas
    What’s the pin setting on the trailer? 30 or 36”??
  11. liner
    477
    685
    Mar 15, 2008
    ontario
    36 inch pin setting.
