282 Pete
Discussion in 'Peterbilt Forum' started by 282 Pete, Aug 23, 2024.
  1. 282 Pete
    282 Pete Bobtail Member
    Aug 23, 2024
    Getting my 77 282 v6 going again, will post pics/updates along the way.
    For now, In need of some parts if anyone here can point me in the correct direction or have some laying around that would be greatly appreciated.
    1- Clutch cable
    2- LH hydraulic tilt cab latch. Need the piston cylinder rebuild kit or whole assembly
    Once I get those squared away she should be drivable again.
  3. AModelCat
    164,385
    SmallPackage and 282 Pete Thank this.
  4. 201
    201 Road Train Member
    12,751
    26,228
    Apr 16, 2014
    high plains colorado
    282 Pete Thanks this.
  5. 282 Pete
    Aug 23, 2024
    282 is essentially a 352 just with one less axel. Everything should be interchangeable. Made a FB account yesterday and stumbled upon some groups. Even some 362 parts can work. Might have to go the Frankenstein route.
    201 Thanks this.
  6. SmallPackage
    5,774
    18,532
    Dec 20, 2019
    Marion Texas
    Clutch cable can be made of you can find a shop that builds them. In these parts that is a place called San Antonio Brake and Clutch. They also do speedo and tach cables. The cab lift and latches are gonna be hard to source. My ‘73 352 pump and lift assembly is mia. Someone else “borrowed” it years ago. The pump should be able to be rebuilt by a hydraulic shop or if you have a bearing and seal supply store you might try it yourself and get them to match up the parts.
  7. SmallPackage
    5,774
    18,532
    Dec 20, 2019
    Marion Texas
    Also you may already know about them but Courtland Truck Works in Courtland Ca. may have some parts. They have saved, collected, and restored many old Petes over the years. They have many acres of them. Very knowledgeable on vintage Petes. It is very hard to get them to answer the phone tho. Lol. So don’t give up.
  8. 282 Pete
    Aug 23, 2024
    Thank you greatly appreciated. Got her running today, made a cable myself and was able to use the old hardware. Ordered some parts from Peterbilt for a 362 that I read work if my fix fails later on. Found a hydraulic shop that’s worked on old Pete’s. Unfortunately they’re not open on weekends so I’ll try Monday, was informed of Courtland yesterday forgot until you just mentioned it lol. Thank you again.
    SmallPackage Thanks this.
