289 M 1975 Peterbilt battery cable problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by turnerbros, Mar 29, 2025.
  1. turnerbros
    turnerbros Bobtail Member
    10
    11
    Mar 29, 2025
    Hello,
    First time posting
    I have inherited a 289 M 1975 Peterbilt from my late father. Cummins engine, 2 axle runs just well as it ran when I was 10 years old. I am planning on selling it but before I do there seems to be battery cable problem. It will start and run well with 5 connections, but 6 connection causes the batteries to smoke out. Meaning one the wires isnt grounded properly. I wanna do right by who would buy it. When it comes to semi trucks,I am not mechanically inclined and since the truck is an anitque I cannot find a techinical mannuals for this particular model. I am not sure if it is bad cable or battery cable wires, or connecter. Any advice would be helpful. I'm not trying to get taken to the cleaners if I call a mobile repair service. Thanks in advance
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Trace out where your main battery cables go to. Peterbilts typically run 2 main positives and 2 main grounds both of which should be connected terminate at the starter.
    it appears as though your trying to hook one of the grounds on the positive.
    Then one of the jumpers between batteries needs to jump across the positives. There’s no need for the jumpers to cross all three batteries but it won’t hurt to add them either. I’d just add positive. Jump cables between and pretty sure the blue sheath cable is gonna be a ground. But trace it to be sure.
  4. turnerbros
    10
    11
    Mar 29, 2025
    I will definitely take look first thing when I wake up. thank you very much. have a blessed day.
    Goodysnap Thanks this.
  5. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    Quick question. Is that a 12 volt system or does it have a series parallel switch?
  6. turnerbros
    10
    11
    Mar 29, 2025
    12 volt system I believe.
    wore out Thanks this.
  7. wore out
    wore out Numbered Classic
    17,305
    214,669
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Very nice little unit. What ever you do don’t just give it away. I agree 100 percent with what @Goodysnap posted above
  8. turnerbros
    10
    11
    Mar 29, 2025
    Oh I not gonna give it away I had it appraised its worth at least 19K.
    Bean Jr. and wore out Thank this.
  9. Bean Jr.
    5,573
    9,929
    Mar 30, 2014
    You need to be sure. If it has a series parallel, it's designed for 6 volt batteries hooked up in series instead of parallel. Please make sure.
    Nice truck
    Oxbow, turnerbros and AModelCat Thank this.
  10. AModelCat
    164,538
    2nd the above, it's the right age to have had a series-parallel switch. With an SP switch it'll be 24 volt starting but a 12 volt system with 12 volt alternator. Definitely want to confirm if it has one.
    I think they were normally four 6 volt batteries. However, I did use four 12 volt batteries on my KW with an SP switch and it seemed to work. Been so long I can't exactly remember how I connected them.
    Oxbow and Bean Jr. Thank this.
  11. turnerbros
    10
    11
    Mar 29, 2025
    You guys are godsend. thank you
    Oxbow Thanks this.
