3 axle alignment
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by istumped, Mar 22, 2019.
  1. istumped
    istumped Medium Load Member
    503
    241
    Feb 8, 2015
    Can someone reccomend a good alignment shop in illinois. Preferably central or northeast illinois(I'm 60 miles south of Chicago). Been to 3 different alignment shops same issue. Steer tires wearing on edges.
  3. pavrom
    pavrom Road Train Member
    3,213
    7,397
    Apr 29, 2012
    NE illinois
  4. istumped
    503
    241
    Feb 8, 2015
  5. VWbeagle
    VWbeagle Bobtail Member
    17
    11
    Dec 21, 2016
    Wearing outside of passenger and inside of driver steer is usually caster, or drives are pointing to the ditch. Caster can be adjusted with a shim, or by axle correction, but only on a solid axle truck. Some trucks have a hallow axle and there is no fix except rotating front tires constantly to keep up with the wear
  6. Ridgeline
    22,701
    122,212
    Start with replacing your shocks on the drives then get an alignment.
  7. Jacoooooooo
    Jacoooooooo Heavy Load Member
    748
    1,054
    Oct 20, 2013
    I can recommend you a good shop for alingment, but it’s in Lima, OH.
