3 wires for two terminals?
Discussion in 'CB Radio Forum' started by CaptainKirk, Mar 21, 2013.
  1. CaptainKirk
    CaptainKirk Light Load Member
    91
    20
    Dec 8, 2012
    Virginia
    I've got an older Cobra 29 NW WX ST that has 3 wires. Maybe all CB's are like this and I'm just missing something. I don't know if it's affecting my range or not because I've heard an improper ground can do that.
    The middle wire is solid yellow with a fuse link, one is red/yellow with fuse link and the third is black/yellow. I have red/yellow on the positive terminal and black/yellow on the negative terminal. Solid yellow is not hooked to anything.
    I'm getting a range of about a half mile at best on level ground.
    Any ideas?
    Thanks for reading.
  3. EZ Money
    EZ Money Road Train Member
    So it is connected with the fused wire not hooked to anything?
    Not sure why it has a 3 wire power connection.....not typical on any Cobras i have owned.
    If you are getting out only 1/2 of a mile then something is really wrong.
    First thought would be antenna and coax. Then SWR way off.....
    The owners manual for that radio shows the normal 2 wire power cord.
    http://cobra.com/downloads/manuals/29WXNWST.pdf
  4. ssgtdirt
    ssgtdirt Bobtail Member
    5
    Feb 5, 2013
    Solid yellow should be for constant battery feed for radio memory purposes. If you don't want your radio power on a switched circuit (only work with key on) you can connect both red & yellow wires to hot battery stud. Range issues are likely related to swr. Check to make sure coax and ant are properly attached, and not broken or cracked. Ant length may need to be adjusted to get your swr right.
    Sent from my ns4g using Tapatalk 2
  5. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    I don't believe your radio truly has a 3rd wire required. Yes your pigtail may have it though. Some radios do require a constant 12 VDC for the memory. Chances are you have a universal pigtail. Most Cobra 29's don't lose memory when disconnected. It's usually the 18 series Cobras that need the 3rd wire.
    When they told you an improper ground could cause range issues, they were referring to the antenna ground. Yes if the antenna is not properly grounded, your SWR will be high and a high SWR is one of the many things that will hinder your range.
