3406 id
Discussion in 'Trucks [ Eighteen Wheelers ]' started by southtx, May 24, 2011.
  1. southtx
    southtx Light Load Member
    55
    27
    May 22, 2011
    hondo, tx
    Hi all, just got assigned to a different truck, it has a 3406 cat. My question is how to determine which model it is, the tag is worn pretty bad, all I can make out is the 3406. The tag says its 475 horse-490 max. The truck is a 2000 year model. Thanks in advance.
  3. Diesel Dave
    9,531
    31,597
    Jan 20, 2010
    Hesperia, Ca.
    Im not sure about this but I believe some inspections stations required that I.D. engine plate on there. In California it's MANDATORY. Isn't a federal issue though ?
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Try the easy way - hook up computer with ET and read ECM data...
    The other way - truck ID sticker
  5. oilfieldtrash
    oilfieldtrash Light Load Member
    226
    107
    Oct 17, 2009
    Jones,Oklahoma
    Call the dealer with the vin. It will be no problem. As long as it is the original engine. Qiuckest and easiest way.
    southtx Thanks this.
  6. mslashbar
    mslashbar Medium Load Member
    602
    813
    Jul 22, 2009
    elizabeth,co
    If it's a 2000 model, it would be a 3406E motor.
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    3406E I sugest too. but may be C15 too...
  8. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    probably a 2ws 3406E
  9. 05chopper
    05chopper Light Load Member
    169
    22
    Dec 25, 2008
    USA
    Below turbo engine serial number is stamped into the block if you have insulation then there is a small window to left of turbo.
  10. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    Many times the EPA sticker, on the oil cooler will give you the engine family.
  11. southtx
    55
    27
    May 22, 2011
    hondo, tx
    Thanks for all the help. Its a 3406e
