3406B head spacer plate
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Sep 13, 2025.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,415
    1,738
    Dec 4, 2019
    What’s the criteria, for determining whether your used spacer plate, is deemed, “acceptable”?
  3. Diesel Dave
    9,645
    32,579
    Jan 20, 2010
    Hesperia, Ca.
    As a core or to put back on the engine ?
  4. Diesel Dave
    9,645
    32,579
    Jan 20, 2010
    Hesperia, Ca.
    My former CAT mechanic was rebuilding a E engine, he always measured (mic) the spacer plate before install. When the local Pete dealer parts guy showed up, he “Mic” the plate and it was off. Wasn’t flat straight across. And it was Wrapped in genuine cat paper. Go figure.
    PSM379 and mile marker 27 Thank this.
  5. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    Good, to reuse. How to measure, where to measure and tolerances.
  6. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    If new aftermarket ones, are sold, “out of spec”, that’s worth knowing, as well.
    Diesel Dave Thanks this.
  7. Diesel Dave
    9,645
    32,579
    Jan 20, 2010
    Hesperia, Ca.
    He mic the outer and inside the holes all around. I don’t know what the numbers would be or what’s acceptable if there off slightly. @wore out , your phone is ringing
    beastr123 Thanks this.
  8. AModelCat
    164,571
    Pitting, thickness out of spec, warpage, damage are grounds for replacement IMO.
    As for aftermarket spacer plates I would not waste a cent on a Yellowmark spacer plate. I bought one for my A a few years ago and right out of the box it measured both above and below the acceptable spec range for thickness. Genuine CAT was fine.
    cke and Diesel Dave Thank this.
  9. wore out
    wore out Numbered Classic
    17,309
    214,770
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Use new every time and always measure before install. A lesson I’ve learned the hard way.
    the original spacer plates were aluminum. I still have a couple of them laying around.
    Feedman, beastr123, Oxbow and 3 others Thank this.
  10. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    Point me in the right direction, for a new one.
  11. wore out
    17,309
    214,770
    Jun 5, 2013
    It’s not that easy. You need to measure your protrusion first. The stock one is .338 part number 6I-2981
    the thinner one is .335 and part number 6I-4303 which isn’t what I’ve got in my mind but won’t come to me. I hate getting old
    cke, beastr123, Oxbow and 2 others Thank this.
