3406B NEW OWNER QUESTION
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 260REM, Oct 15, 2025.
  1. 260REM
    260REM Bobtail Member
    10
    8
    Aug 9, 2023
    I have a 04MG 3406B 425 in a 1990 379 and a 13 speed. Truck had been sitting prior to me buying. I have been working on old gal, runs, drives, sounds good. My issue is, while going through the lower gears it seams fine as in it gets up to speed but doesn't set you back like an e model and when i get to 5th or 6 gear it really takes off. The best way i can describe it would be like hitting the powerband of a 2 stroke dirt bike. Does this all sound normal? I know it doesn't have the torque of a new engine butt it seems a little lackluster on the lower 4 gears and the sudden get up and go seems odd to me.
    I have had pump and advance overhauled, new fuel lines, new intercooler(boosts to about 27psi) new filters. It did this prior to pump work also.
    I have not had a trailer on it yet and this is my first mechanical engine and still a work in progress.
    Is this normal?
    Thanks for any help,
    DAN
  3. wore out
    wore out Numbered Classic
    17,310
    214,842
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    It’s very normal. Oil pressure sets the afrc valve to limit. It takes boost to set it to go mode
  4. 260REM
    10
    8
    Aug 9, 2023
    Thanks @wore out . Good to hear im worrying about nothing.
    What kind of idle rpm settings are you guys running? Mine is about 600 but with the throttle control turned up to 700 it smooths out. Should I idle her up or leave alone?
    Rideandrepair and Oxbow Thank this.
  5. wore out
    17,310
    214,842
    Jun 5, 2013
    I run 700-750 I’ve never been a fan of 600
    Rideandrepair, Oxbow and Sons Hero Thank this.
  6. 260REM
    10
    8
    Aug 9, 2023
    I'll idle the old gal up. Seemed a little low to me. When I put pump back on , I set it at the same rpm as previous setting. Previous owner said he idled it down to slow down his backing speed.
    If you have any advice on the B model, I'm all ears. Its my first one. I miss the cruise but so far i like the engine and its lack of sensors, wiring, and plastic parts.
    Thanks for your help.
  7. wore out
    17,310
    214,842
    Jun 5, 2013
    Just don’t lug it. They are a very dependable power plant. They are strong but not a race car. Don’t buy into the whole advance the timing deal and it will last a long time
  8. 260REM
    10
    8
    Aug 9, 2023
    10-4 will do.
    Thanks again for your help.
    DAN
    Rideandrepair, MAMservices and Oxbow Thank this.
  9. Gilbyson
    Gilbyson Bobtail Member
    39
    59
    Apr 26, 2012
    Wyoming
    I got a throttle cable for my cruise control. Its mounted to the left of the steering column, and attaches to the throttle lever on the fuel pump. Its not very safe because the brakes don't deactivate it. So you got to be quick to push it in when you need to slow down.
    260REM Thanks this.
  10. 260REM
    10
    8
    Aug 9, 2023
    My truck has one of those by the seat. So far I have only used it to idle it up to build air or maybe heat if I'm doing work on it. Next time its out ill give it a try.
  11. BillMot
    BillMot Light Load Member
    83
    152
    Oct 7, 2025
    Atlanta, GA
    It sounds like your 3406B is behaving pretty much as expected. These engines are known for their strong mid-range torque, but they don't always shine in the lower gears, especially when unloaded. The "powerband" effect you're feeling in the higher gears is likely the engine hitting its sweet spot.
    Since you've already overhauled the pump and advance, replaced fuel lines, and installed a new intercooler, it seems like the engine is in good health. The lower-gear lack of punch is a common characteristic of the 3406B, particularly when it's not under load.
    Once you hook up a trailer, you'll likely notice a more consistent power delivery across all gears. Keep an eye on boost levels and fuel pressure, as fluctuations can indicate issues with the turbo or fuel system.
    260REM Thanks this.
