3406b turbo upgrade???
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 704mover, Mar 8, 2018.
  1. 704mover
    704mover Light Load Member
    60
    22
    Mar 8, 2018
    I have a #7fb30241, ar#4w2354, jwac 3406b in a 1985 Peterbilt 359. Turbo is needing replaced (oily pipe on intake side). Engine is a 400hp but seems to lack a little power. It makes 27# of boost but rolls black smoke every shift unless you ease into the throttle. I know that's fuel that is being wasted. Turbo is currently an OR5381. Would a 199119 be a power upgrade? What can I do to get a little more power? This is a work truck, not a hot rod. I don't want to kill it, but it smokes like a dog when you get on it. I know something isn't quite right. Any help is appreciated. Thanks
    AModelCat Thanks this.
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    @wore out yer phone is ringin.
    beastr123, Oxbow and SAR Thank this.
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    It's a b model it's gonna smoke
  5. wore out
    wore out Numbered Classic
    17,294
    214,345
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    177148 is a better choice in my opinion, the 119 does a good job but it can be a little laggy.
    spsauerland, Oxbow, SAR and 1 other person Thank this.
  6. AModelCat
    164,495
    This must be a troll post. OP actually gave us all the info needed to give a decent answer.
    (Not ball busting, just refreshing to see a post that doesn't just say "I need more power, will a 199119 turbo solve all my problems?")
    spsauerland, wore out and Oxbow Thank this.
  7. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    @Oxbow runs a couple B models.
  8. wore out
    17,294
    214,345
    Jun 5, 2013
    You should check air flow across the cooler as well, seen a few stopped up in my time. Your kinda describing the symptoms
    spsauerland, Oxbow and SAR Thank this.
  9. Oxbow
    Oxbow Road Train Member
    13,649
    141,427
    Nov 24, 2015
    Could check the a/f ratio to see how it is set, or just ease into it a bit more.
    I have a 177148 on one. It helps tremendously on the low end with much quicker spool up than the stock turbo. I often wonder if it isn't just a little less at wot once everything is spooled up and you are pulling hard at 1700 or better.
    There is another option out now that I have heard of called Blalock I think...they call it a switchblade turbo?
    It is still wastegated, but is designed differently by the looks of it. I'm not sure if they have one for a B model.
    Anyone else heard of it?
  10. Oxbow
    13,649
    141,427
    Nov 24, 2015
    Which cooler are you referring to on a jwac?
    SAR and wore out Thank this.
  11. wore out
    17,294
    214,345
    Jun 5, 2013
    I have but not enough to recognize anything more than the name
