3406B
Discussion in 'Ask An Owner Operator' started by Jasonar15, Dec 9, 2017.
  1. Jasonar15
    Jasonar15 Medium Load Member
    669
    519
    Aug 6, 2017
    have a 3406B and it blows a little blue smoke at idle and acceleration. What is the cost of a rebuilt for this engine?
    Oxbow Thanks this.
  3. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    I think that is typical of a b model, but not 100% sure.
    @wore out?
    cke, snowman_w900, Grubby and 3 others Thank this.
  4. SAR
    2,756
    36,654
    Nov 26, 2011
    ND
    @Oxbow I forgot you run a couple of these too!
    snowman_w900 and Oxbow Thank this.
  5. Oxbow
    Oxbow Road Train Member
    13,594
    140,833
    Nov 24, 2015
    On mine when they are warm they are pretty clean at idle, and just barely a bit of haze when working them (after the turbo catches up). Very blue during cold start this time of year.
    I just had one built at Cat in which I took the engine out and took it to them, but we did not do a complete. It included new cylinder packs, polished crank, reseal brakesaver, new rods and mains, new thrust washer, sleeved one counter bore, new compressor, and inspected all the remaining parts. The block was stripped completely down though. I did not need a new head, nozzles, pump work, water pump, oil cooler, or any other external parts. The bill was 17K.
    snowman_w900, Grubby and SAR Thank this.
  6. cmrdev
    cmrdev Medium Load Member
    370
    373
    Oct 13, 2017
    You can get a rebuild done pretty cheap. However, its a gamble on who does it. Doesn't matter if its a reputable guy. I personally would spend the 15-20k on a quality rebuild from cat. Nice to have that warranty and piece of mind.
    NightWind and Grubby Thank this.
  7. SAR
    2,756
    36,654
    Nov 26, 2011
    ND
    Does the smoke smell like unburned fuel or burnt oil?
  8. Dale thompson
    5,416
    46,675
    Nov 20, 2013
    commerce twp,mi
    could just be worn nozzles blowby is a much better indicator of a need for overhaul
    cke and Oxbow Thank this.
  9. cmrdev
    370
    373
    Oct 13, 2017
    sorry if this sounds like a stupid question buddy but why not replace water pump at that time even so?
  10. Jasonar15
    669
    519
    Aug 6, 2017
    Doesn’t have much blow by
    cke, Oxbow and SAR Thank this.
  11. Jasonar15
    669
    519
    Aug 6, 2017
    Haven’t tried to smell it. Will tho
    snowman_w900, cke and SAR Thank this.
