3406E. Boost
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Joe Bob 53, Mar 3, 2020.
  1. Joe Bob 53
    Joe Bob 53 Bobtail Member
    6
    Mar 3, 2020
    Need someone with sis access tell me what my boost spec was from cat on 6TS26690 , I've had cat turn up to 550 but still seems a little on weak side I've changed fuel pump, and pressure control valve (check valve) builds about 40 pounds boost I believe should be higher
  3. 062
    062 Road Train Member
    6,321
    33,958
    Oct 20, 2013
    @pushbroom @spsauerland
    40psi of boost is pretty strong. If you had a cat house put a file in that would be a lo-nox file.
    Brettj3876 and pushbroom Thank this.
  4. okiedokie
    okiedokie Road Train Member
    13,779
    108,985
    Jun 13, 2011
    PNWET
  5. pushbroom
    pushbroom Road Train Member
    1,788
    7,394
    Sep 1, 2012
    40lbs is nuts. 22lbs from factory. Even at the 550 rating they only run 26 or 28.
    Wasnt til the 6nzs they started running 35 or so.
    Didnt crack 40lbs boost until the twin turbos came out.
    SAR, FoolsErrand, Shawn2130 and 6 others Thank this.
  6. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    If you have the factory waste gated turbo then you must have the wastegate line pinched off.
    There is no way it would make that kind of boost stock.
    40 on a stock turbo and your pushing it.
  7. 062
    6,321
    33,958
    Oct 20, 2013
    I’m seeing 32-36psi with a 78mm on a lo-nox 550 file.
    SAR, spsauerland and pushbroom Thank this.
  8. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Perfectly normal with a non WG turbo.
    40 is not normal with stock turbo
    SAR, Diesel Dave, spsauerland and 2 others Thank this.
  9. dirthaller
    dirthaller Road Train Member
    1,126
    13,387
    Sep 22, 2011
    Coloratah
    You know that your truck isn’t going to pull an 8% grade @ 80,000# as fast as your diesel pickup pulls your 8000# camper right?
    Brettj3876 and Joe Bob 53 Thank this.
  10. Diesel Dave
    9,593
    32,182
    Jan 20, 2010
    Hesperia, Ca.
    What was the boost before the upgrade ? And what hp was it stock before ?
    Joe Bob 53 Thanks this.
  11. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    That's about normal, even with a bigger turbo, my Borg does maybe 45 psi and mine was a 550 stock and has the 6999 injector codes. You go down the "need more power" rabbit hole and there's no turning back. I'm sort of looking for a little bigger injectors, maybe a cam, of course then I'll need an even bigger turbo, it never ends if you don't stop yourself.
    booley Thanks this.
