3406e Camshaft difference
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by UpperDevker, Feb 18, 2018.
  1. UpperDevker
    UpperDevker Bobtail Member
    36
    11
    Feb 14, 2018
    Hello everyone
    It’s my first post here and I can’t seem to figure out my question after extensive research.
    I have low HP 3406e(2ws08414) with a 1439153 camshaft. One of my injector lobes is starting to get worn down. I ordered a replacement camshaft through YNG LLC. They sent me 1390538 camshaft which is rated for the higher hp arrangements. They said that they bet their left nut on it that it will work with no problems. On the contrary the cat dealer say that these cams don’t interchange, but they don’t have info on how they differ . What will happen if I put the
    1390538 into 1439153 engine arrangement?
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    I posted reply in other thread were you posted the same question... I am slow to type so check that one out!
    SAR, Oxbow and Diesel Dave Thank this.
  4. Diesel Dave
    9,558
    31,775
    Jan 20, 2010
    Hesperia, Ca.
    Seems when a new member seeks advice in a desperate mode.... they will post all over without realizing a single post we all see it .
    AModelCat and Oxbow Thank this.
  5. UpperDevker
    36
    11
    Feb 14, 2018
    Thanks man! I’ll give him a call
  6. UpperDevker
    36
    11
    Feb 14, 2018
    It seems that when a old member has a stick in his arse he would leave a comment like that.
    Rideandrepair and Diesel Dave Thank this.
  7. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    can you please copy and paste you reply or link to the thread as I have a friend with a similar issue and we want clarification on caterpillar definition of static timing
  8. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
  9. DieselTech_Aus
    274
    309
    Dec 20, 2017
    WA
    the difference between the available arrangements of 2WS and 5EK
    software, cam and injectors for different 550hp arrangements.
    turbo on his unit is a 0000 650hp borg warner so that is up to the task.
    if you want to PM it that's fine. hes only making 30psi boost (normally they go 38/40psi) with the 550hp file. even if he turns the 8501/23/57/2.82kg/min injectors up to flow that of a standard 8502/24/3.07kg/min its still gutless only putting 460hp to the ground and pyro doesn't go past 430 deg C
    current cam 1361157
    file 1708226
  10. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    What the serial number of the engine and what is current flash file, cam p/n, injectors, etc. Guessing this was an overhaul that you uprated HP.
    SAR and Oxbow Thank this.
  11. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    The current cam P/N for the one you listed is a 187-9381. It is used in 5EK upper HP settings with 58's/8502 injectors. The flash file you listed is for Pre-low NOx 1LW 550/1850 file that would use 57's/8501 inj and a 139-0537 cam. Only specs Cat gives on cam is actual lift and only difference is of two cams is 0.001 lift on injector lobe, but I bet shape and rise of injector ramp is different and duration and lobe separation angle could be different on intake and exhaust. If you have 58's/8502 in it, have you tried the 170-8132 5EK 550/1850 file. This way injectors, cam, and ecm flash match.
    SAR and swaan Thank this.
