3406e exhaust studs
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by cat 03, Dec 31, 2023.
  1. cat 03
    cat 03 Bobtail Member
    24
    8
    Mar 22, 2013
    I keep breaking exhaust studs on a 1997 6ts 3406e I tried stainless studs had one break I went back with factory gaskets and studs with all new spacers made sure all surfaces were clean made sure manifold was pushed all the way together and centered on studs for expansion torqued all in sequence to 41 ft lbs I check the torque at every oil change. 2 months later I have two more broke studs any suggestions
  3. AModelCat
    164,604
    I've never had to do a manifold on a Cat. I do wonder though if pushing the manifold all the way together is the issue? The sections have nowhere to expand to so they try to force each other apart possibly.
    I do recall Cat has a tool for centering the manifolds, no idea what it looks like or how it works.
  4. MRMTRANS
    MRMTRANS Medium Load Member
    407
    440
    Apr 28, 2015
    Crankshaft dampener might need to be replaced. Once it doesn't absorb the energy from the crank when it rotates, that energy goes to all sorts of places. Vibratech says mine for a S60 Detroit should be replaced every 500k miles. Before I learned this years ago, I had lots of problems with bolts/fasteners: manifold bolts, AC clutch bolts, alternator bolt for the old V-belt style, etc. I've heard you will wear out a clutch faster, too
    Magoo1968 Thanks this.
  5. cat 03
    24
    8
    Mar 22, 2013
    I was told by pdi and pittsburgh power to push the sections together and then make sure I had space between stud and manifold hole sides so with hear and expansion it would not snap off the studs what do you think?
  6. cat 03
    24
    8
    Mar 22, 2013
    This is a new long block with new dampner and accessories
  7. MRMTRANS
    407
    440
    Apr 28, 2015
    Yah, 2 months seems real fast for bolts to come loose with a bad dampener anyhow.
  8. 062
    062 Road Train Member
    6,327
    33,967
    Oct 20, 2013
  9. Diesel Dave
    9,651
    32,636
    Jan 20, 2010
    Hesperia, Ca.
    Anything heat related to do with a Cat, I only bought Genuine Cat parts(Hardware). I had the head replaced when I had my Cat a few years back, My Cat Guru warned me to have all studs and nuts replaced because when you reinstalled the exhaust manifold, the old ones might bottom out and you will have an exhaust leak eventually.
  10. cat 03
    24
    8
    Mar 22, 2013
  11. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    I used to go through that until I put a new manifold on. Haven't had an issue since.
    Diesel Dave Thanks this.
