3406e low power
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mjtrucking, Jan 1, 2015.
  1. mjtrucking
    mjtrucking Bobtail Member
    28
    4
    Jan 22, 2013
    I have a 99 w900 with a 3406e 475 that has low power, it builds 35# of boost, runs really smooth, it just doesn't pull well.
    I have checked air filters replaced fuel filters didn't seem to change anything. Anyone got idea for me to check?
    Thanks, Matt
  3. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    any whistle?
    check hoses to cold air(cac) check turbo and wastegate,
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    `When you pull off exp/way if you dont have a heat gun, spray some water out of spray bottle to see if all cil. on EX. manifold steam the same when you spray them a weak injector wont get man. as hot. the cat shop can do a test also but at a price?
  5. T800H
    T800H Medium Load Member
    608
    296
    Apr 2, 2010
    The Keys
    it boost 35 psi, so even if the cac leaks it would build power. kind of weird that it builds 35 psi and no power, you would think if it had no power it would not boost that high.
  6. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    maybe the muffler is cloged up to much back presure or the boost gauge is bad
  7. vikingswen
    vikingswen Road Train Member
    1,436
    1,990
    Jun 14, 2012
    In the Stratosphere
    What is your fuel pressure? I am not sure if you have a fuel pressure gauge, but low fuel pressure could be your problem. My 3406E runs around 75-80psi, but a lot of guys shim the spring to run about a 100-105psi for better throttle response.
    DogHouse83 Thanks this.
  8. 6nz-kw
    6nz-kw Bobtail Member
    48
    13
    Dec 28, 2013
    Jamestown OH/Holly Hill FL
    Mjtrucking,I had the same problem,same truck,and motor,it's hard to fathom,but try this fix! The fuel tank vents,on mine collapsed,and the best thing to do is,unscrew them from the top of the tank,and cut the check valve out of the caged part of the vent, and throw it away,and clean your rubber tubes out,and put back on,it's a simple no $$$,out of pocket fix,just be sure to come back,and let others know,if this helped,or not... PS, you can see my thread on the kenworth section!
  9. mjtrucking
    28
    4
    Jan 22, 2013
    I had a 550 file put in, that helped the tech repaced the fuel lines at the same time, it still feels doggy but its better. Ill try the vents on Monday and let you know thanks Matt
  10. 6nz-kw
    48
    13
    Dec 28, 2013
    Yeah Matt, sounds just like how my truck acted! I had a 600 American brakesaver file,a fuel temp harness,a fs1023 fleetguard primary fuel filter,and 74 -19 fuel numbers,fuel pump shimmed up to 100 psi,and a grand rock aerocab true dual exhaust kit,made it run ok,but it never really woke it up,until I removed the check valves out of the tank vents,and I haven't ever replaced the fuel lines,from the tanks,to the junction block,just the junction block forward! Just please let everyone know,if this helps you out
  11. wore out
    wore out Numbered Classic
    17,294
    214,350
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Wrong it will build boost with a cac leak sometimes, and won't pull for nothing. Boost pressure and fuel go hand in hand. Takes fuel to make boost. Definitely pull the balls out of vents as you can do that in a truck stop parking lot. If that doesn't help check fuel pressure and for boost leaks.
