3406E Sputtering Only Under Acceleration
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jordonh, May 8, 2025.
  1. Jordonh
    Jordonh Light Load Member
    52
    38
    Jul 1, 2022
    North Carolina
    Hey Ya’ll
    So I have a 3406E Cat in a FLD120.
    Recently got my engine rebuilt 2 months ago and it has started sputtering and smoking upon acceleration in the lower gears, if u park it and rev it to a certain rpm it will just stutter then go back to normal operation. It’s like a here and there type of thing it’ll act up then u can drive it for 2hrs without no issue.
    Already replaced fuel filters/ check valves-cam sensor so far. Sounds like it’s either sucking air somewhere or it’s a wiring/injector issue.
    https://youtube.com/shorts/0juHP_zhHJc?si=ls9V7AylFzHiGFeK
  3. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,952
    Oct 31, 2023
    I'd take it back to wherever rebuilt it. Could be as simple as an injector harness. Nobody can diagnose your issue from behind a keyboard.
    Jordonh and Magoo1968 Thank this.
  4. Star Rider
    Star Rider Road Train Member
    1,760
    17,237
    Sep 23, 2019
    I'll bet the cam gear is 1 tooth off.
    Jordonh Thanks this.
  5. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    more than likely junk injector
