3406E Ticking
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JimmyWells, Apr 11, 2017.
  1. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    My engine has developed a ticking. It sounds exactly like an exhaust leak but I can't seem to find a leak anywhere. I've also developed an occasional backfire out of my left air can (W900L) when I left off the throttle very quickly. Could these symptoms be related to a single cause? Been reading a bunch about possible head gasket leaks, rocker issues, injectors, valve problems etc etc. Wanted to get some better input on the matter, thanks.
    Oxbow Thanks this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I never saw this on a 3406 but a worn exhaust cam lobe can prevent exhaust from escaping properly. Then when the intake opens the pressure in cylinder pops out the intake. So yes a valve train problem can cause this.
    maggard359, Oxbow and JimmyWells Thank this.
  4. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    This would be very unfortunate since I just put a CAT remanned head on in January.
    Oxbow Thanks this.
  5. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    I also hope that is not your problem that is just what came to mind for one problem that could cause all of your problems. I would look under the cover it could just be a loose adjusting screw, jake issue or something.
    JimmyWells and Oxbow Thank this.
  6. Gambino1994
    Gambino1994 Light Load Member
    187
    103
    Jan 22, 2009
    causing a situation
    I broke an exhaust rocker arm on my 3406e once. It was while decelerating up an off ramp empty, no jake brake on. It was all of a sudden a very loud tick, it would puff the intake boots each power stroke of the engine since the exhaust or whatever it would be would come back through the intake. I only drove it the couple remaining miles home though before I took it apart. The rocker broke cleanly, cam and valve bridges were fine
    JimmyWells Thanks this.
  7. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    It sounds like a loose valve or injector, as to why it is loose will determine how many meals of beans and rice you will have to eat to fix it.
    If you just did the head then it is likely that one of the adjusters was not locked tight after the rack was run, if you run the rack again VERY soon you can dodge a bullet.
    If the cam is going flat on a lobe then running the rack will correct the issue for short time but it will return as the cam lobe continues to grind itself away.
    Good luck, here's hoping you just have a loose adjuster :)
  8. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Thanks all. I'll be pulling the covers to have a look today.
  9. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    This may be beyond my expertise. After pulling the valve covers, I don't see anything out of the ordinary. The head is under warranty from CAT but I'll lose my tune if I take it there. Someone had mentioned swapping ECMs but wouldn't I need the injector codes to do that?
  10. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Not necessarily they may be close enough,but if it runs rough cat may change the trim codes in the loaner ecm.
  11. RET423
    432
    534
    Apr 6, 2017
    Kalifornia
    If you have a loose rocker it will still "look ordinary", you have to manually rotate the engine and check each one when it is off the cam lobe to see if the lash (or preload in the case of an injector) is too loose. Cat will not mess with the computer when they run the rack, that will come later if running the rack does not cure the problem or reveal the failure of a hard part. If it is missing you need to run a cylinder cutout test to narrow down which hole; that will save a lot of experimentation and guesswork.
    Running rough and ticking sounds a lot like an injector lobe or rocker failure.
