3406E won't fire up.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Luwi67, Jan 24, 2016.
  1. Luwi67
    Luwi67 Heavy Load Member
    750
    485
    Oct 24, 2012
    Long island
    It just cranks and cranks and cranks. I don't use the truck that often, I did start it up this past Friday to move it, fired right up. This evening it won't.
    A little backround, 250k on Cat OPT outframe overhaul. I've had the truck for 13 years and it has never not started. 1997 Pete 379.
    The self diagnostics on the cruise control toggle flashes 55 which is all systems OK. I tried a little either into the air cleaner and nothing. fuel is not gelled at all.
    I did notice from the cranking that the oil pressure rose but, the fuel pressure didn't. Is the fuel pressure supposed to rise on the gauge while cranking for say 10 seconds.
    I'm kind of lost at this point, is there anything else I can check. Thanks.
  3. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    push the shrader valve and see if you have fuel pressure, if there's no pressure reprime the motor with the hand pump (200 pumps sometimes), it sounds as though you're not getting fuel up to the cylinders. Before priming if you have any available I'd recommend cracking both filters loose and topping them off with power service/whatever additive you have on hand. You may want to have a can of WD40 handy as well and a helper if you can find one.
    I wouldn't recommend ether, and if you didn't have enough ether in the air cleaner it still won't start I fought this problem earlier this year and for 2 days straight last year. took almost half a can of Wd40 and pulling the boot on the head to get it to fire off finally.
    Also when priming the motor watch for fuel around the primer pump if you get fuel on the primer pump handle you need a new primer pump and that could very well be the cause of the motor losing prime which is what it sounds as though has happened.
    Are you getting any smoke from the stacks or anything of that sort? If you're getting smoke you're getting heat and at least some amount of fuel up to the injectors it just may not be enough to get the motor to fire off. I feel your pain though had my motor torn down july of 14 to the tune of 22k, before the overhaul it could be well below 0 with gelled fuel in the tanks and that motor would start might not run long but it'd start. Now if the #### temp is below 20 I've got it plugged in and my fingers crossed when I push the starter.
    Ruthless and Luwi67 Thank this.
  4. AModelCat
    164,604
    2nd priming the fuel system. Watch out using ether. Its like meth to engines. Don't want to get it hooked.
    Luwi67 and 379exhd Thank this.
  5. 379exhd
    2,925
    3,153
    Jun 25, 2012
    +1 on ether being meth. I carry a bottle for frozen brakes, I've had better luck with WD40 for starting fluid doesn't seem to have the crack effect of always needing it if used too much
    Luwi67 Thanks this.
  6. Luwi67
    750
    485
    Oct 24, 2012
    Long island
    Thanks, I'll try that tomorrow. Do you mean the test port under the rubber cap here:
    A few years ago I removed the hand primer and replaced it with a block off cap. I always meant to buy a new primer and keep it in the truck for an emergency but, haven't yet. In 13 years I have never used the hand primer and I do all the filter changes on the truck. Maybe I'll pick one up tomorrow and see if that helps.
    Her is the block off cap:
  7. Luwi67
    750
    485
    Oct 24, 2012
    Long island
    I've never used either before, a friend had some and suggested it. He sprayed it into the grill of the air cleaner while I cranked it for 10 secs. I didn't really want to do that but he said if it started it would show us a fuel related problem, so I gave it a shot.
    I'll stay away from the stuff and concentrate on the fuel pressure and prime. I'll check for smoke at the stacks too, didn't notice any today but, then again I wasn't looking.
  8. 379exhd
    2,925
    3,153
    Jun 25, 2012
    yes there should be a valve under that rubber cap. push the valve in and it should squirt a little fuel if there's pressure. Don't feel bad I've got one truck with a bad primer pump that runs daily I'm just too #### lazy to fix the $15 primer pump until I service it next time.
    Since you can't prime the motor you may need a helper and some sort of starting fluid if you can get the motor to fire off you can use SMALL stream to keep it running until you get enough fuel pressure to keep her running. I'd definitely recommend topping the filters off though. As I said I use WD40 and have never had an issue with them getting addicted but I could see that happening over time. just like with ether. good luck with it
    Luwi67 Thanks this.
  9. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    If you got no primer I would get someone to crank the engine while you crack the return fuel line at the check valve. This will confirm if you have fuel and also bleed any air out .
    Luwi67 Thanks this.
  10. AModelCat
    164,604
    I think the issue with ether is it washes away the lubricant on the cylinder walls and causes the liners to glaze up. WD40 works just as good and its a lubricant.
    tommymonza and Luwi67 Thank this.
  11. josh polk
    josh polk Light Load Member
    142
    64
    Dec 20, 2015
    Bowie TX
    Lossen the fuel line on back of the head take air hose put air in the fuel tank through the vent tube pressure It up its best to use a regulator set at about 5 psi till u got steady flow of fuel at the back of the head
    Luwi67 Thanks this.
