3408DI
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Youngtrucker19, Nov 4, 2013.
  1. Youngtrucker19
    Youngtrucker19 Light Load Member
    280
    23
    Feb 13, 2013
    What's the fuel mileage on a 3408DI cat? Every time I look for it pops up stuff about cars or does give a number.
  3. claytonr1973
    claytonr1973 Light Load Member
    266
    289
    Jun 1, 2008
    miami,ok
    Fuel mi and 3408 should not be used in the same sentence. One guy I talked to claimed 6 on a good day, most will tell you 4.5-5. Then you have to consider the added weight of a 3408 vs 3406.
  4. wore out
    wore out Numbered Classic
    17,200
    212,631
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I have one in a truck real similar to what I drive every day. 4 would be a fair number. My uncle ran one for years in the late 70's and early 80's he said his had no trouble getting 3.3 if you crowded it much
  5. Youngtrucker19
    280
    23
    Feb 13, 2013
    I was jw cause some say you can get a lot with the right stuff and others say you can't get hardly any
  6. wore out
    17,200
    212,631
    Jun 5, 2013
    Finding some one who knows the combination and the cost may b a factor.
  7. G3Truks
    G3Truks Light Load Member
    214
    446
    Sep 25, 2013
    Back in the day I was lucky to get 4. Usually got about 3.5 with it hooked to a 5X4 and 363 rears pulling produce.
    We didn't care about fuel in those days and it would pull a hill like it was flat ground.
    Good luck with it.....if you have an application where you need that kind of power you might consider a 3406B...better fuel mileage, lighter and easier to work on when the time comes.
  8. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    3408di the more it sounds like a pop corn cooker the less mi. it gets, 4 mpg. loaded light [77 coe kw 5/4 3>90s)
  9. snowblind
    snowblind Heavy Load Member
    775
    636
    Jan 29, 2011
    conover nc
    you haul the right freight....fuel not issue,then think of cool factor
