350 Cummins injector problem?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jan 8, 2024.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,415
    1,738
    Dec 4, 2019
    Recent build in a 350 small cam. Exchanged injectors and rebuilt heads. Noticed excessive white smoke, slight miss sound and fuel coming out of the exhaust manifold at the front 3 piece union. Pulled turbo and exhaust manifold, started engine and #2 is producing lots of white smoke and fuel. All other exhaust ports looked fine. Went deeper and pulled #2 injector and o-rings look good and are new. Any ideas?
  3. Big Road Skateboard
    7,068
    40,045
    May 2, 2021
    Are you 100% certain the valves were adjusted correctly there?
    About the only possibilities are low compression or bad injector
    Last Call and Oxbow Thank this.
  4. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    Yes, I’m definitely sure. I set the injector first at 72”lbs or 6’lbs, then exhaust .023 and intake .011.
    MACK E-6 Thanks this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Double check adjustment. Swap injector to another cylinder. Does the miss fire go with the injector?
  6. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    So, low compression = stuck ring? Once head is off, is there anyway to remedy a stuck ring without dropping pan and pushing piston out?
  7. OLDSKOOLERnWV
    19,103
    288,854
    Low compression can be valves leaking as well as rings not seated. Did you notice any excess blow by from the crankcase vent tube?
    As mentioned earlier swap that injector with another hole and see if the smoke / fuel follows the injector….
  8. SmallPackage
    5,774
    18,532
    Dec 20, 2019
    Marion Texas
    Bad injector push tube?
    OLDSKOOLERnWV Thanks this.
  9. W923
    W923 Road Train Member
    1,419
    4,386
    Feb 28, 2022
    Did you have the Jakes on it yet?
    Maybe wrong adjustment there is holding the exhaust valve off is seat…
  10. OLDSKOOLERnWV
    19,103
    288,854
    Not likely, does it ring when you bump it against a piece of steel? If so it’s not taking on oil….
    SmallPackage Thanks this.
  11. W923
    1,419
    4,386
    Feb 28, 2022
    Is it only at idle? Will it do it with a load on it?
