4 pod puenamatic
Discussion in 'Oilfield Trucking Forum' started by Cat_man, Jan 27, 2018.
  1. Cat_man
    Cat_man Bobtail Member
    Can anyone tell me if you can use a larger 4 pod trailer to haul frac sand? Does it make it harder to unload or slower?
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Never hauled sand but you should be fine, only thing is the trailer wont be as full as if it was a 3 hopper.
  4. plater1
    plater1 Medium Load Member
    341
    241
    Jan 24, 2011
    back in NY
    I ran with an owner op who had one. It didn't take him any longer to load or unload. He had the same amount of sand #48k, as everyone else. it was kind of overkill though as fully loaded would only fill up 1/2 his trailer. His trailer was a bit taller though.
  5. Redimix
    Redimix Light Load Member
    50
    104
    Feb 26, 2011
    Dallas
    Technically it would work, but not ideal. Loading may require more effort to not over axle. The basic stuff like top air and steel drop tees (or hog Tees) will still be required.
    900 to 1300 cubic feet are ideal.
  6. Cat_man
    Thanks everyone for the response I just found a really good deal on one and was going to use it to get started with.
  7. Masonkid
    Masonkid Bobtail Member
    44
    28
    Nov 20, 2017
    In North Colorado, pneumatics should start going for cheap, boxes are taking over. Just finished our last pneumatic job lasy week.
  8. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Boxes are starting to take over everywhere. Been seeing a lot of them up here in pa/wv/oh as well
  9. Powder Joints
    7,983
    8,384
    Sep 25, 2007
    Rosamond, SoCal
    4 pod will work fine, no difference loading load it above the pod just rear of center, maybe you might have to split between 2 center lids, but probably just center rear. Check axle weights on every load as you pull off the scales.the sand will spread as it loads, unloading will take a bit longer because you have 1 more pod to deal with. The main reason to use doubles for frac sand is you dont have to worry about axle weights on double, on a 4 pod semi you do.
    bottomdumpin Thanks this.
  10. flightwatch
    flightwatch Road Train Member
    1,249
    1,251
    Jun 22, 2011
    Somewhere in Texas
    They are, but it's not necessarily a good thing. They pay much worse per load compared to a pneumatic with the reasoning being that you should be able to run more loads per day. But when those boxes are stacked 200 deep at the railhead trying to get loaded or you have a 400+ mile round trip LOH like we do out here in West Texas, I can't see how they are making much.
  11. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Around my area 50 mi turn paid 350 a load from sand box. I see a lot of O/O around my area pulling boxes
