4" strap / winch....excess strap
Discussion in 'Flatbed Trucking Forum' started by tony97905, Mar 12, 2015.
  1. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    I am new to trucking and flatbedding and have seen guys double the strap over, place it in the winch and tighten after folding over excess but not sure how they make it look so easy. I run the strap behind the rub rail, run it through the winch and then fold the excess so the strap holds it when tightened but this seems to be much slower than the other way I mentioned. Can anyone tell me the easiest way to handle the excess and give a detailed description. I'm aware you can wind it all on the winch but I end up with way more strap than will fit on the spool.
  3. Lonesome
    Lonesome Mr. Sarcasm
    11,645
    24,258
    Dec 15, 2007
    Northern Indiana
    How can you have more strap than what will fit on the spool? I leave my 4" straps wound on the spool when not in use, and there is no problem with it fitting.
  4. tony97905
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    We have step decks with "short" winches and use 30' & 35' straps due to hauling welded steel structures of various sizes....and they physically won't fit.
  5. plant
    plant Heavy Load Member
    861
    806
    Sep 21, 2012
    Los Angeles, CA
    You are doing it the correct way. Less chance of slippage and no spongeness/compression like when you have a bunch of strap wrapped around the winch.
  6. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    yep. maybe post pics for newbs to see what you are talking about.
    i'm not flatbedding anymore.
  7. brsims
    brsims Road Train Member
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    We have the drivers take the straps completely off when unloading. Straps stay with the driver, not the trailer. When I throw straps, I run down behind the rub rail, completely through the winch, and fold the excess. You'll get faster at it with experience. Learning flatbedding takes time. It's a specialized skill.
    jbatmick Thanks this.
  8. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Maybe the guys doing it faster than he is aren't running the entire strap through the winch, maybe they are folding the strap and just tucking it in one side of the winch?
    MJ1657 Thanks this.
  9. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    I cheat with mine. I throw it over and attach the hook end. Then go over to the other side to the end of the strap. Make as many loops as necessary walking towards the trailer. Flip the loops under the strap, then you should have a single loop going down, feed that through the rub rail. Squish the end a bit and feed it through the winch. It depends on what style winch you have, I have 3 bar which are easy to feed through, and I make sure there's lots to grab. With the slotted kind you only need to feed it through one side. But make sure the strap has a full turn before tightening anything or it will jump out.
    This method is less forgiving to straps that flap going down the highway but I've never had a problem. Some guys feed it through the winch then loop it.
  10. Allow Me.
    10,760
    12,548
    May 28, 2009
    Rancho Mirage, Ca.
    Do it the way the manufacturer says to, which is strap thru the winch completely thru, not folded and put thru, which is lazy way to do it. My preference is safety first. But there's guys who will argue that point.
    mc8541ss and damutt Thank this.
  11. mc8541ss
    mc8541ss Road Train Member
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    I personally would never just run it through one Side of the winch. Not arguing with anyone, that's just me.
    Just keep watching the guys that are making the loops and you will get the hang of it. Don't try for fast at first, get the technique and speed will come.
    Slow is smooth, and smooth is fast.
