48' versus 53' Reefer
Discussion in 'Ask An Owner Operator' started by JHaulingS, Jun 9, 2014.
  1. JHaulingS
    JHaulingS Bobtail Member
    47
    Jun 4, 2014
    My neighbor & I are going into the business, but 1st we have to get equipment. He feels we should buy a 53' reefer. I'm thinking if we can get a good deal on a 48'er, is not having that extra 5' really going to hurt us that much? I mean, how many times are we going to get loads that fill us up completely front - back?
  3. jbatmick
    jbatmick Road Train Member
    2,200
    2,510
    Dec 1, 2009
    hastings, Fl
    You are correct about this, and you are also wrong.. MOST of the time that 5 feet will not matter in produce. If the truck were to haul only produce, then I would go 48'.However, odds are you will also load dry FAK ( freight all kinds ) to get to the produce shipping points. While most of this will fit in a 48, quite often the shipper will require a 53.
    I would rather pull a 48, but if I were to buy another trailer, I would drag a 53. You will be better equipped to handle more loads.
    123456 and Classic97 Thank this.
  4. JHaulingS
    47
    Jun 4, 2014
    Thanks, that's what I needed to know, if its going to be worth it. Sounds like, IYHO (in your humble opinion), it is.
  5. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    you also need to think about the time when you need to upgrade your equipment:a 53' have more potential buyers than a 48'
  6. JHaulingS
    47
    Jun 4, 2014
    Another good point, thanks.
  7. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    There is lots of low density refrigerated freight. I used to pull lots of frozen stuff that would fill me to the back door sill and still be under 36k-38k. Now straight meat/fish/poultry or produce loads, as stated you're probably ok with a 48'. I prefer 48's myself due to living in a congested corner of the country, in a state with somewhat tight overall length laws.
    Also keep in mind that some shippers are prickly and will turn away anything that isn't a 53' even if they're only putting 6 pallets in the entire trailer (Kraft comes to mind but I'm sure there are others).
  8. JHaulingS
    47
    Jun 4, 2014
    That's interesting!
  9. Winkjr
    Winkjr Road Train Member
    1,804
    614
    Oct 18, 2011
    Marlton NJ
    Jpenn is right about the shippers. My company only has 1 53. I have a 48 usually there's no problem getting loaded.
  10. JHaulingS
    47
    Jun 4, 2014
    What exactly is Jpenn right about, "shippers are prickly and will turn away anything that isn't a 53' "?
  11. 201
    201 Road Train Member
    12,764
    26,262
    Apr 16, 2014
    high plains colorado
    Hi J, I agree with most, I did a lot of reefer, mostly cheese and I even had to single a couple out on a 48. If you've never pulled a 53, there's a big difference between a 48 and a 53. You can get around a lot better with a 48. Like most said, the only time you will run into trouble is with non-refridge backhauls, if that's an issue. Besides, with 53 being the norm, you could probably get a 48 dirt cheap. Heck, years ago, I pulled 40' reefers, with those old noisy Thermo-Kings rattling away. Good luck
