5'' straits
Discussion in 'Mack Forum' started by Dwightsch, Jun 12, 2015.
  1. Dwightsch
    Dwightsch Bobtail Member
    14
    Has any one used those inserts that go into strait pipes to muffle the exhaust on a truck I have a 98 ch dump truck. Its just way to loud But dont have enough room between the cab and bed to put mufflers and no room under cab for resonater. I found some inserts on Iowa 80 that fit into a five inch pipe. can any one tell me how well this will reduce the noise and how much it will affect my power and will it hurt the engine
  3. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    Loud pipes saves lives jesus saves souls.I ran macks with straight pipes always thought they sounded good to me.why dont you have any room under cab to put a resonator my 99 r model roll off had one which i took off under the cab.
  4. Dwightsch
    14
    Just not enough room on ch to put resonater under cab its a tight fit to get your hands between frame and exhaust pipe ( I like a quiet truck )
  5. Diesel Dave
    9,536
    31,612
    Jan 20, 2010
    Hesperia, Ca.
    Double post........, you already posted the same thing. And yes..........the inserts will work so will still wool.
    Dwightsch Thanks this.
  6. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I have 5" dual straights with inserts on two of my trucks. The inserts take alittle of the bark out of the exhaust but by no means makes it quiet
  7. Dwightsch
    14
    Where did you get your inserts
  8. mslashbar
    mslashbar Medium Load Member
    602
    813
    Jul 22, 2009
    elizabeth,co
    I got mine from 4-states. They're not real easy to install, they fit tight.
  9. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
  10. Dwightsch
    14
    How well do they work?
