5th Wheel greasing
Discussion in 'Freightliner Forum' started by ChemicalMover, Jul 11, 2019.
  1. ChemicalMover
    ChemicalMover Bobtail Member
    Our company now owns a Freightliner Cascadia Day cab. The question I am asking is how often should the 5th wheel be lubed/greased? We very rarely have to unhook from our trailer we pull. We stay strictly local only running 120 miles per day. We have one mechanic telling us that since we are local that it needs to be greased 2 times per week. This seems a bit extreme. Another mechanic is telling us since we run only local and the low amount of miles, once every 3 months would be sufficent.
    Any help would be appreciated.
    Thanks
  3. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    Put a slick disc on it and never grease.
    rabbiporkchop Thanks this.
  4. Powder Joints
    7,982
    8,383
    Sep 25, 2007
    Rosamond, SoCal
    Minimum would be once a week, a slick disk is the way to go on local..... If you can see nice shiney metal, and gouges you waited too long
    x1Heavy Thanks this.
  5. JohnnyC
    JohnnyC Light Load Member
    173
    65
    Feb 17, 2009
    virginia beach, virginia
    I put a little grease on mine every 10,000 miles. I drive 150 - 250 a day. Never had a problem. Flip it about once a year and grease the mechanisms. Replace the springs as necessary. They now make a spray 5th wheel grease thats great. I have a Fontaine with plastic \ teflon bushings. Check for wear every 6 months. Fontaine and Holland have online videos.
  6. MartinFromBC
    2,769
    12,484
    Oct 19, 2018
    That is very little use, so every couple weeks should be more than enough. After doing it for a few months, you might find that is too often, and go down to every three or four weeks. Even if you run 7 days a week, that is only 840 miles per week, and with the same trailer behind it all the time, you won't be hooking up to some unknown dry trailer.
  7. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Twice a week sounds right. If you unhook and it looks dry, you need grease.
    The truck handles alot better with a greased fith wheel.
    Give it some time and you will see. It will be easier to to drive and stay where you want it. A dry fith wheel is like driving in a side wind, it will wear you out fast.
  8. Banker
    Banker Road Train Member
    4,501
    14,506
    Aug 19, 2012
    I may go 6 months without unhooking my trailer and I had the slick disk and really liked it. The problem I had is when I did have to drop the trailer the ring that holds the disk on comes loose every time. Since my trailer sits inches off the ground it is a pain to put another lock ring on by myself without getting covered in grease. I may go with a permanently mounted disk to the 5th wheel instead. If you 183E7371-7F77-48EC-BC9D-03E8F3B5E55A.png go the grease route you probably will want to do it every week or so or you will end up with a dry top plate.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I do it weekly as I drive on gravel roads fairly often.
    I drop my trailers on the weekend and can see the difference between weeks with a lot of gravel miles and weeks with little gravel miles.
    Some times the fifth wheel is bone dry, others it looks like I just did it yesterday.
    skellr Thanks this.
  10. Diesel Dave
    9,614
    32,338
    Jan 20, 2010
    Hesperia, Ca.
    7E6836E4-F3A5-4193-803C-6066F6AA3D58.jpeg No mess............
    skellr Thanks this.
  11. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    even if you have slick disk you need to put grease on trailer king pin and under plate locking mechanism. 5th wheels with oem permanent mounted slick lube plates are good ones . Holland makes them.
    Rideandrepair, x1Heavy and speedyk Thank this.
