5th wheel height
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Loadx, Oct 10, 2020.
  1. Loadx
    Loadx Bobtail Member
    13
    10
    Jun 27, 2020
    Just bought a used 379 single axle and have it hooked up. Front of trailer is 4in taller than rear so I think my 5th wheel needs to be lowered if possible or changed to a low pro 5th wheel. Any tips on looking to see if mine is adjustable or not (it's not the original)? If not, anyone know where to get a good cheap low pro? Thanks
  3. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Need close up pics of the risers. Can’t tell from the pic, but it looks like it may already be lo pro.
    Rideandrepair Thanks this.
  4. Loadx
    13
    10
    Jun 27, 2020
    Pretty positive this one is not adjustable. Just not sure if I can find one lower?
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Get the number off the tag on the top plate. Call your local Holland dealer. Ask for the lowest mount. The part between the plate and slider. Or go to the bone yard. Doubt you will loose more than 2 inches.
    The low one has the air cylinder in front of the plate.
  6. SmallPackage
    5,777
    18,546
    Dec 20, 2019
    Marion Texas
    Have you hooked to a regular semi trailer to see what the clearance is? I don’t think I’d lower it. I would fab a way to slide that one forward out of the way (for option to pull semi trailer) and add another fifth behind it just for the gooseneck types like you have. Custom multi-porpose.
    BoxCarKidd Thanks this.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I got a used truck that use to pull tanker. I pulled dry van and set off height warning lights on a 13’9” bridge.
    Found out the fifth wheel had 11” high saddle. Had it changed to a 7” saddle.
    Cost close to $1,000
  8. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    I had skipped the first pic. I agree and have done the same thing. Mine had stationary plates which located the ball a bit more to the rear. Never had a problem that way.
  9. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    Go to truck salvage yard some one on here just had one put on for 275 The one you have is not a low pro look like 3" risers.
  10. pushbroom
    pushbroom Road Train Member
    1,788
    7,394
    Sep 1, 2012
    Trailer neck isnt adjustable?
    spsauerland and AModelCat Thank this.
  11. Loadx
    13
    10
    Jun 27, 2020
    Trailer neck is at its lowest setting. I'm going to search around and see if I can find a smaller
