5th Wheel position
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Iceman1643, Sep 24, 2024.
  1. Iceman1643
    Iceman1643 Light Load Member
    91
    126
    Dec 29, 2023
    Bmore MD
    I'm on a journey to get my 2022 Freightliner to ride better. Was talking to an older trucker and one thing he suggested was to have the 5th in the proper position. I run a fixed 5th Wheel and the kingpin sits about 4"(+/-) forward of dead center of both drive axle.
    Ole boy said to lessen the truck wanting to buck like a bronco, have the kingpin dead center of the 2 drives......
    Is this correct? Would it improve the way the truck n trailer will ride? Science tells me, the further back that weight point is the lighter will make the frontend. Which is not necessarily a good thing.
    I'm usually always heavy, between 70k and 80k.
    Any knowledge/opinions are greatly appreciated!
  3. Diesel Dave
    9,632
    32,517
    Jan 20, 2010
    Hesperia, Ca.
    Different trucks, different positions.
  4. Short Fuse EOD
    2,791
    8,760
    Jul 29, 2015
    Midwest
    Generally, Having the fifth wheel center between the two drives is a decent position for a ride comfort. I’d say most guys position their fifth wheel for function.
    Rideandrepair and Iceman1643 Thank this.
  5. Oakland Raiders Forever
    Oakland Raiders Forever Medium Load Member
    417
    495
    Feb 24, 2020
    In general I’ve found that the further back the smoother the ride
    Rideandrepair and 201 Thank this.
  6. 201
    201 Road Train Member
    12,763
    26,260
    Apr 16, 2014
    high plains colorado
    "Stretch 'er out, boy" was the cry. More weight on the steer will give a rougher ride, and if no scales, everybody put the 5th wheel as far back as it would go. I'd look elsewhere for a better ride, I suggest a KWhopper. ;) They are called "Freightshakers" for a reason. Being a newer truck, you can rule out anything worn, and perhaps a rear suspension adjustment is needed. Freightliners generally ride pretty nice. What kind of wagon?
    JForce28, Rideandrepair and Iceman1643 Thank this.
  7. Iceman1643
    91
    126
    Dec 29, 2023
    Bmore MD
    She's a 2022 Cascadia with 303k on the dial.
    Bought it a few months back and stopped being company driver. But just before that I had maintenance align, adjusted, and shimmed the suspension. Just had 2 new shocks installed on the steers. New meat all the way around. Cab shocks replaced with Gabriel Fleetline. Still gotta get the 4 drive shocks done, and the Centramatics installed on all 3 axles.
    And now adding sliding the fixed 5th Wheel back about 4/5 inches in the "to-do" list.
    Rideandrepair Thanks this.
  8. Iceman1643
    91
    126
    Dec 29, 2023
    Bmore MD
    Yes, I'm realize that. I was looking for a "general rule of thumb"
  9. Grumppy
    3,233
    11,401
    Dec 11, 2010
    West Monroe, La
    If you're always at 70 - 80,000, primary is going to be making it legal. I would think you're set at legal now since you're always at gross.
    Like someone else said, you need to be looking somewhere else for your comfort. You wont have any room to be messing around with the 5th wheel.
  10. 201
    12,763
    26,260
    Apr 16, 2014
    You didn't say what you are pulling. Does it ride rough bobtailing? The wagon may be the culprit. I've found, generally, the shocks do little if anything.
  11. Rideandrepair
    17,548
    56,858
    Aug 8, 2015
    Shocks are probably original. Change them and see what happens. My Truck rides great when the air ride height is set properly, and with new shocks. Bad shocks and height slightly off, especially if it’s low, and it rides like crap. It’s an old FLD. The difference is night and day. Start there and see what you got. Moving the fifth wheel back a bit might help. Not much. Hardly worth it. As long as you don’t currently have trouble scaling loads. I run my slider at about the same position as yours. That’s 1 notch forward of dead center on the slider itself. Each notch shifts about 500 lbs of weight. Works best for 99.9% of loads with my Truck. Helps mpg’s to keep the gap closed up between cab and trailer. Get familiar with load distributions. Weighing the heavy loads. Learn what works best, use the trailers sliding axles to your advantage. Too heavy on fifth wheel, or too heavy on trailer tandems, either way will cause bucking. The latter being dangerous in slick conditions. Usually if it axles out evenly, that’s about as good a ride you’re going to get when heavy. Use that as a reference for comparison. See how it rides. The culprit is probably the spring ride trailer. Shorter wb Trucks by design buck more. Not much you can do about that. The air bags have gotten bigger in the last 20 years. Seems to be the key to a better ride. They run softer, and If shocks are bad, bounce more, causing it to buck. Bad shocks are useless. Like having none at all. You could literally run without them and not notice any difference. More importantly they slow down the movement of the suspension, lessening the bucking. Considering the larger air bags, good shocks are key to a better ride. Too much movement also wreaks havoc on the whole suspension. Wearing out bushings, height valve, tires, driveline faster. They’re worth every penny. That’s my been my experience anyways.
