5v ground wire on D12
Discussion in 'Volvo Forum' started by dorlia2, Jun 6, 2022.
My truck had this problem. Change the oil pressure sensor and see if it solves the problem.
I have a problem that I can't find out what it is.
Mid128 pid94 fmi 7
I changed almost every part in relation to fuel and the truck still tells me fuel feed pressure low and refuses to start -
Oil pressure sensor, oil temp. sensor and EGR valve #1/#2 all share 5v reference. 9 times out of 10 one of the EGR valve harness has rubbed and is grounding because they are so long. Usual spot is where they cross over front of engine from passenger side to driver side.
Hello.. do you know what reason would cause diesel not to be flowing through my return line to the fuel tank? My truck cranks but does not start and it does not get its full power when it drives
Sounds like fuel pump failure. It is a common D12 issue. Fuel pump and accessory drive should (must) be replaced as a pair.
Thanks a lot. I changed the pump only but not the accesory drive. I would change it and see if it solves my problem. Thanks
