6×2 question
Discussion in 'Ask An Owner Operator' started by feldsforever, Oct 2, 2020.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    I don't get why I'm always spinning. At first I thought the actual drive axel was coming off the ground. But there is constant connection to the ground. When I lock in the diff both sides just spin.
    This truck has super singles, some one suggested running 15-20 lbs less air on each drive tire. This is to have more tire on the ground, more contact equals more traction.
    Has any one eles heard of this? Or have other tips or tricks?
  3. Ruthless
    Ruthless Road Train Member
    9,168
    91,042
    Aug 28, 2010
    The City.
  4. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    If it won't lift drop the air on the dead axle.
  5. 201
    201 Road Train Member
    12,764
    26,262
    Apr 16, 2014
    high plains colorado
    Is it a KW? They had or have a funky traction system that I hated.
    feldsforever Thanks this.
  6. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Sorry I should have added that. Wasn't 100% caffeinated when I posted.
    2016 cascadia dd13. Auto. The dummy don't lift.
    D.Tibbitt and 201 Thank this.
  7. feldsforever
    1,453
    1,440
    Nov 22, 2019
    So, I was about to let the air out as suggested. When I noticed the power axle (front drive) rubbers where taller
    They are brand new as of last Wednesday. Will deflating the dummy still work.?
  8. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    The air bags equalize until you have the same ground pressure at each tire. They don't even know your tires are different sizes. So once you relieve that pressure, it will put more weight on the drives, regardless of tire size. So even though they're still on the ground, they aren't "pushing down on the ground" anymore.
    stillwurkin and feldsforever Thank this.
  9. nikmirbre
    nikmirbre Road Train Member
    5,584
    10,336
    Jul 27, 2011
    High Point NC
  10. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Pls explain how that works.
  11. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    For air bags to be equal in pressure, they need an equal amount of opposite pressure. So they should all be pushing down on the axles with the same amount of force. Am I wrong in this? I'm not always the sharpest tool in the shed, and I'm not afraid to admit it, if I'm wrong. I'd rather get it right, than be posting misinformation.
    D.Tibbitt, daf105paccar and okiedokie Thank this.
