6nz boost?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 01blackz28, Jun 28, 2012.
  1. 01blackz28
    01blackz28 Light Load Member
    150
    19
    Oct 29, 2011
    I'm boosting 27psi but its really slow to build boost compared to our 600hp isx. For example if i'm pulling a hill,drop half a gear, and get back on the throttle it almost a full second before the guage even moves. But when it does it goes right to 25-27. It doesn't miss and there is 1 new injector in the motor. From what I understand if the truck ran rough it could be an injector but it doesn't. The truck feels like it runs good but not the isx 600. What are some common problems that may cause this?
  3. bull hauler
    bull hauler Medium Load Member
    300
    80
    Apr 23, 2012
    Have air to to air pressure tested
  4. CatPowerC15
    CatPowerC15 Medium Load Member
    347
    91
    Feb 18, 2010
    Siler City, NC
    What he said....then if it checks good, pull the turbo and check the divider in the turbo and manifold. Also check the turbine wheel....
  5. western diesel & performa
    western diesel & performa Bobtail Member
    10
    Nov 7, 2012
    Check fuel pressure and install sight glass to make sure no air in fuel it may also need to have fts fls changed has it just started this or has it been doing this for a while
  6. silver dollar
    silver dollar Medium Load Member
    481
    211
    Jan 31, 2009
    Central North Carolina
    Installing a sight glass. Tell me about this. Is it a permanent install? Where does it install? A where do you buy it? thanks
  7. kellysaville
    kellysaville Bobtail Member
    27
    5
    Jan 11, 2012
    Denver Colo.
    Check your boost sensor , it will cause the boost rise slowly
  8. Buckshot7cz
    Buckshot7cz Light Load Member
    168
    26
    Oct 16, 2012
    Sandy Oregon
    what he said
  9. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Check the gauge.
    Cetane+ Thanks this.
  10. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    Slow build up of boost can be caused by a number of different things.
    the wastegate actuator/diaphragm on the turbo could have a broken spring in it allowing the wastegate in the turbine housing to open at low boost pressures.
    the aftercooler or the piping and hoses between the turbo and engine could have an air leak
    as someone else stated the center dividers in both the manifold and turbine housing can crack and erode due to heat, this will cause slow response
    another thing to look for is exhaust leaks in the exhaust manifold before the turbo. The slip joints leaking or cracks will lower exhaust gas back pressure before the turbo. This will cause slow response
    Cetane+ and kat man Thank this.
  11. CarhaulerKris
    CarhaulerKris Bobtail Member
    How do you trouble shoot a boost sensor?
