6NZ ECM
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by cgilliland, Oct 11, 2019.
  1. cgilliland
    cgilliland Medium Load Member
    321
    744
    Mar 13, 2017
    I bought a '99 W900 that was N14 but swapped to 6NZ. It runs great but is governed at 72MPH. I took it to a local shop and they said they needed a password for the ECM. The seller doesn't have it. Does it sound right that a password is needed?
  3. AModelCat
    164,441
    Off to the CAT house for you! If its a password set by a previous owner/fleet they should be able to erase it. If it needs factory passwords to alter that parameter, they can generate them.
    Oxbow, cgilliland and Goodysnap Thank this.
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Yes, they can be password protected. Plenty of folks that can get around that without trip to dealer.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I here the Cat house installs low NOX tunes on everything that comes in. Oh just the latest updates. Is the true?
    Oxbow, Rideandrepair and cgilliland Thank this.
  6. Robert Stoddard
    Robert Stoddard Bobtail Member
    11
    Oct 6, 2019
    Good evening I have a 2006 Cummings ecm Voltage going in and out is reading correctly all fuses and relays are good check the ECM fuse and it is good the issue is I hooked my JPro software to the engine and it’s not reading the motor double checked everything all connections are good vehicle crank in that start in the computer is not picking up the engine? Had someone come with the Cummings software same thing? my Supervisors having to replace the ECM is there anything else I should be looking for?
