6NZ File
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NoLuckCanuck, Jun 30, 2012.
  1. NoLuckCanuck
    NoLuckCanuck Bobtail Member
    16
    5
    Jun 8, 2012
    Alberta, Canada
    How hard is it to get ahold of the 6NZ file? I have someone that can flash it, I just want the stock 550 6NZ file.
  3. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Its pretty easy if you know the right people. I'm just trying to figure out if you know someone who can flash it, why don't they have the file already?
    little cat 500 Thanks this.
  4. NoLuckCanuck
    16
    5
    Jun 8, 2012
    Alberta, Canada
    You're absolutely right. I misunderstood him he has files. he just needed the file name that would best work. I was under the impression that any 550 6NZ flash would work on the bridge/MBN ECM but he says some are better then others. So if I may redo my question. which flash file would be best suited. And should I mess with the trim codes or leave them till I manage to afford the new turbo? If so which should I use? I currently am running the fuel temp mod and an air pressure regulator on my boost sensor as well as a restrictor on my wastegate line. Once I flash Ill only keep the fuel temp (so very impressed with that one)
  5. NoLuckCanuck
    16
    5
    Jun 8, 2012
    Alberta, Canada
    By the way thanks to everyone on this site for the mods Ive found here. I appretiate all the help as does my fuel card!
  6. underpsi
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Use the oldest 550hp 6NZ file he has and if you want little extra power use a brakesaver file. I wouldn't recommend you change the trim codes, ever new turbo or not.
    NoLuckCanuck Thanks this.
  7. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    The MBN ECM limits what file you can use. The part number of the ECM is 240-5303 which isn't compatible with the old 6NZ files. Use any file that is for a 6NZ53999 or lower serial number, but has a newer release date for the best programming in the file. The injection timing or emissions won't change from a file written in 2002 to one written recently with these files. The changes in the files during this time frame have to deal with diagnostics and communication between the laptop and the trucks other computers, not emissions.
  8. NoLuckCanuck
    16
    5
    Jun 8, 2012
    Alberta, Canada
    What exactly is a brakesaver file?
  9. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    it's a cat file with the cat brakesaver program in it. it's cat's engine brake that works off the back of engine with the engine oil. like a hydraulic pump but it puts drag on the drive line with pressure as you pull the lever down.the program is setup with alittle more hp than normal programs.
  10. lightfoot500
    lightfoot500 Bobtail Member
    49
    6
    Jul 30, 2011
    Pittsburgh, PA
  11. lightfoot500
    49
    6
    Jul 30, 2011
    Pittsburgh, PA
    Mr haney, can you reply to my question when you have time, sir. Thank you. What difference would i see in an older 550 file? Current one is 6TS 14926 set at 600hp. A friend said he used 601 hp 5ds file.
    Cat ecm file for 550 5EK
