79 superliner 300
Discussion in 'Mack Forum' started by papamoonshine, Nov 15, 2016.
  1. papamoonshine
    papamoonshine Light Load Member
    103
    13
    Aug 25, 2013
    I found a 79 superliner with the 300 and a 5 speed. Dont know a whole lot about them. I ran pete's mostly 389 and 379. I did run an old R model with a 300 in once upon a time but I didn't spend much time with it.
    are the 5 speeds like a twin stick that has one with the 5 gears and then another stick is high low and reverse?
    if that is so could I gear it up so I could run 70mph and would I have some decent power? I know Mack's are different then other companies cause the HP rating is at the wheels and not at flywheel.
    Its a day cab with a camel back sups. I would in time put a coffin sleeper on it and put an air ride of some sort on it. Truck is really cheap. I haven't gone to look at it personally yet but from pics looks really clean.
    thanks for the help.
  3. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    A Mack 5 speed is just that 5 speeds no splitter just keep shift to the right
  4. Roger McG
    165
    198
    Oct 22, 2016
    western mass
    I'm not trying to say this wrong but if you have driven peterbilt hoods you will be disappointed with a 300 mack superliner on camelback suspension to beat down the road and beat you apart
    poppapump1332 Thanks this.
  5. 51.50
    51.50 Heavy Load Member
    894
    1,943
    Jan 20, 2016
    Salem Oregon
    The transmission is a 5 speed unless there are two sticks. In 5th gear they ran from 40 mph to 70 mph. One of the selling points was less shifting when new. I remember looking at new ones at a dealer in Bakersfield California. 300 Maxidyne and 5 speed. The Mack transmissions have 3 counter shafts. That makes them run longer before an overhaul is needed. I can explain why but you probably know already.
  6. papamoonshine
    103
    13
    Aug 25, 2013
    Well it's myfirst truck I would own. Trying to do it with the cheapest way to keep start up cost down. I would air ride the suspension and cab. Ran a c12 that was 435 was tired. Had a c15 550 for a short while the 389 had a mx13 at 455. Wasn't impressed with it. I figure I would slowly build it in to a smother riding modern day truck I guess.
    That kinda of Mack trans has the high low and reverse on one stick and the gears on the other stick? Was in a r model was a low boy truck that the county owned.
    I read that some one was getting 10mpg running slower. If your going 70 are you running it way out there on the rpm. Don't know a whole lot about these trucks
  7. papamoonshine
    103
    13
    Aug 25, 2013
    No hard feelings I know that
  8. AModelCat
    164,637
    As someone who is going through the process of updating an old truck I will say that it will not be cheap. I tore into mine and just kept finding more #### wrong. Better off spending a little more up front for something work ready.
    BoxCarKidd Thanks this.
  9. papamoonshine
    103
    13
    Aug 25, 2013
    What are you working on northern? Other truck I was looking at is 80 359 big cam 3 13 speed. On air leaf. Short hood 60" flat top
  10. AModelCat
    164,637
    '80 W900A KW. 3406 Cat w/15 over Eaton.
  11. papamoonshine
    103
    13
    Aug 25, 2013
