7cz flash codes 58 and 21
Discussion in 'Ask An Owner Operator' started by pavrom, Mar 25, 2024.
  1. pavrom
    pavrom Road Train Member
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    tried to start my truck and it didn't. cranking but not starting . drove it last week on Monday- 0 issues . started many times during winter - always started . checked flashcodes and it is 58 and 21 , after researching on the internet it looks like 21 is not keeping the truck from starting ...probably 58 . any suggestions before I try to get ahold of mechanic tomorrow?!
    58 says communication between ecm and truck , I changed ecm last may .
  3. Ridgeline
    22,720
    123,213
    disconnect your ELD and see what happens.
  4. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    I don't have eld
    ...paper logs
  5. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    I noticed my diagnostic port has some oxidation ( green color ) ...probably water leaked ...gonna check tomorrow during daytime
  6. Opendeckin
    Opendeckin Medium Load Member
    495
    1,382
    May 20, 2018
    "Hi. Thanks for asking your question! I will try and help you out.
    Code 21 is defined as a 5 volt supply voltage fault. This indicates the 5 volt supply to all the 5 volts sensors is either shorted or open. Because the Boost pressure, Atmospheric pressure, Fuel temp, Coolant temp, Oil pressure and Intake air temp sensors all use the same 5 volt supply, the engine will run very poorly when this code is active.
    The most common thing that causes the code 21 is one of these sensors is shorted. When this happens, it takes out all the sensors. To troubleshoot, you need to unplug each of these sensors one at a time. If the code 21 remains after 3 seconds, the sensor you unplugged is not the problem. After 30 seconds unplug another sensor, and so on and so on. If the code 21 goes away after unplugging one of these sensors, that sensor is your problem.
    If you unplug all the sensors and the code 21 still remains, the either the engine harness or the ECM is the problem.
    Please reply back if you need more help or have more questions. I am happy to assist."
    Qouted from another site, but seems like an easy way to begin troubleshooting
  7. Ridgeline
    22,720
    123,213
    That will do it, the bus has 5 volts on it, and if there is a short, then it can't communicate.
  8. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    . ...removed the very rear plug of the ecm and did find pin 48 broken also water mixed with dielectric grease ... ...didn't check yet power to pins 70, 52, 53 ..had to go grab a tester
    Opendeckin Thanks this.
  9. Diesel Dave
    9,639
    32,556
    Jan 20, 2010
    Hesperia, Ca.
    o_O This on a pre-emissions engine :cool: ! Maybe I should count my blessings on my Commiefornia emissions compliant truck/engine. :D;):rolleyes:. Hope you get it figured out.
