9200i 2004
Discussion in 'International Forum' started by 77fib77, Aug 6, 2015.
  1. 77fib77
    77fib77 Road Train Member
    11,641
    76,755
    Jul 7, 2010
    St Louis
    I have too many psi (100) on the low side port. Is that only from too much 134 or can it be from a bad "switch"?
    Ac doesn't put out any cold air.
    Do you have to "break" the system to change out switches?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Are you getting 100 with A/C comp. running or not spinning? most have a valve like in a tire stem that makes it safe to replace them.
  4. 77fib77
    11,641
    76,755
    Jul 7, 2010
    St Louis
    100 psi with it spinning. I'm not sure if it is engaged, load diesel engine and all.
  5. devedo
    devedo Light Load Member
    114
    43
    Aug 11, 2015
    What is your high side at? Is your engine fan coming on? If the metal plate on the front of the compressor clutch is spinning then it is engaged. You will hear a load metal click when it engages and the engine fan usually kicks on too.
    It could be from a bad compressor (or control circuit), too low of freon, too much freon, bad expansion valve, or a few others. Really need to know high side to narrow it down some more
    77fib77 Thanks this.
