9400 i
Discussion in 'International Forum' started by TruckerPete1990, Apr 25, 2015.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    Picked up my new 2007 9400 with cummins isk 10speed. MAN she rides good!! problem is i notice the right turn signal indicator does not work but the Signals outside do just not the dash part. IS this just a buble to unplug and replug?(ANSWERED)
    Im looking for a 2007 international 4300 operators manual But cant find one its being up a Service manual BUT only for circlets Dash-Assemblies-International-9400-3411346.jpg anyone know where i can find one? This is my Dash look a like and i got no clue what some of the Buttons do.
  3. woolybully35us
    woolybully35us Medium Load Member
    313
    550
    Mar 13, 2015
    ks
    my 07 is the same way. you have to replace the whole thing. which Is both turn sing. an high beam indicator . you have to buy it from a dealer or salvage . the dealer told me its $400.00 for it . I have lived with out it for 2 years now i'am not paying $400 for it
    TruckerPete1990 Thanks this.
  4. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    any clue where to get the user manuels? its only showing me a circet one and i have 3 swtiches that i dont got a clue for. one is DIAG one says DRAG and other is not marked just on and off.
    I've been researching online looking for a 2007 international 4300 operators manual. Anyone know where i could get one?
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    I can't get a 2007 for some reason, I do have a 2006. Your truck was probably build in 2006 anyway. As far as the turn indicator for the 9400, just remove the center cluster panel. You will see the light sockets for the turn and high beam indicators. The socket just twists a half turn and pops out. There is small bulb in there you can replace.
  6. woolybully35us
    313
    550
    Mar 13, 2015
    ks
    I took mine out thinking I could just replace the bulb . but mine is a little rectangle plastic peace that is held on to the panel with two screws an the wires plug in to it. there is no access to the lights . my truck was mfg in 2006
  7. woolybully35us
    313
    550
    Mar 13, 2015
    ks
    truckerpete your dash set up looks just like mine except I have the white gauge package.
  8. Heavyd
    7,826
    6,276
    Feb 4, 2009
    I have seen some dash clusters that have no bulbs, but soldered in micro LED's. These are not serviceable unfortunately.
  9. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    Well i took it apart today! its a small bulb gonna check hardware store. Heavyd that book you posted doesn't work for mine:( PART_1430076614630_IMAG0008.jpg This is what im confused on is these 2 switches DIAG and the one next it to thats blank.
  10. Heavyd
    7,826
    6,276
    Feb 4, 2009
    I found another one today, try this;
    View attachment 2007 4300.pdf
    As for the switch, remove the switch panel and check to see if there is tag on the connector at the back of the switch to label what it is.
    TruckerPete1990 and double yellow Thank this.
  11. Dark_Majesty_06
    Dark_Majesty_06 Road Train Member
    1,072
    332
    Jun 15, 2009
    Poplar bluff, mo
    I am not a owner nor a technician but usually those DIAG switches stand for Diagnostic.. Yours doesn't have a screen but most have a screen that if you press that switch.. It usually has fuel milage, trouble codes and the such. At least, that's how it usually works in MY experience. Good luck, none the less!
