9400I left blinker
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by LeviTrucker, Jun 6, 2023.
  1. LeviTrucker
    LeviTrucker Bobtail Member
    34
    5
    Mar 24, 2022
    Need some help, have a 9400I left blinder stays on when engaged checked all fuses but the relay won’t click. Right side works and four ways.
  3. LeviTrucker
    34
    5
    Mar 24, 2022
    Anyone ?
    I’ve replaced the signal switch itself, the harness itself is fine no break in the lines relays are fine. I did note that the driver side blinker is very dim and won’t blink when I turn on my head lights and the markers lights switch on the dash, only off will it blink and can hear the relay work. All I can do I think about this and it’s driving my up the wall. Anyone ? I’ve buffed each port positive and ground side. Added 4/0 cable from the battery’s to the starter, frame, motor both ground and positive.
  4. AModelCat
    164,341
    Sounds like the flasher module is no beuno.
  5. LeviTrucker
    34
    5
    Mar 24, 2022
    We’re is that located ?
  6. 062
    062 Road Train Member
    6,323
    33,959
    Oct 20, 2013
  7. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Flasher is in with the breakers/fuses. Staying on is usually an indication that LED lights have been substituted in are not drawing enough current to activate the mechanical flasher bi-metal contactor in the flasher itself. Installing a solid state, or flasher specifically designed to switch LEDs is what you need. If you already have this, they are polarity sensitive and the socket may be wired backwards to what it needs.
    062 and AModelCat Thank this.
