9400i
Discussion in 'International Forum' started by bluerhino, Mar 2, 2015.
  1. bluerhino
    bluerhino Light Load Member
    107
    7
    Mar 10, 2013
    Planning to buy 2006 international 9400i with Cummins ,.10 speed trans. What should I look for need your advice.thanks.
  3. d60-14
    d60-14 Light Load Member
    72
    30
    May 23, 2012
    Find somebody with laptop loaded with Cummins insite, to pull out all the codes, if not take the truck to Dyno, it will show many problems if any or hire a good truck mechanic to check the truck for you.
  4. WitchingHour
    WitchingHour Road Train Member
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    What are the rears on it?
  5. electriccowboy
    electriccowboy Bobtail Member
    11
    If you get it bought, go see the Diesel Doctor in Effingham, IL they can turn it up & remove everything you don't need. I have a 2006 9400 Eagle & after they got done it screams !! the wild ride.jpg
  6. bluerhino
    107
    7
    Mar 10, 2013
  7. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    Check fuel mileage on ecm. It generally reads about 0.5 mpg higher than actual. Good fuel mileage 7+, indicates a careful driver, lighter loads, not a lot of hill climbing. Basically an easier life on the truck. IMO. I would rather buy a truck with 800,000 easy miles than 500,000 hard ones. Suspension, bushings, hangers, etc... can also tell the tale. On the Cummins it may be worth a few bucks to pull the cover and look over the cams, lifters, bearings, etc... you'll want to do it shortly after buying anyways. Might as well do it beforehand so you know what you got.
  8. bluerhino
    107
    7
    Mar 10, 2013
    Thanks .my mistake it's a 2006 with Cummins 450 HP he mentioned 15L
  9. WitchingHour
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    450 would be a Family 1 engine, where their "sweet spot" is supposed to be around 1400 RPMs.. with 3.58s, presumably a .74 OD transmission, and perhaps 295/75R22.5s, you'd be looking at 62.7 MPH at those RPMs. If you were looking to cruise faster than that, might be better to find a truck with 3.36s.
