96 freightliner classic
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Wyndian, Mar 8, 2019.
  1. Wyndian
    Wyndian Bobtail Member
    Mar 8, 2019
    I turn my lights on, top front marker lights on trailer work, blinkers work and brake lights. Nothing else. I've tested the plug at the truck. Black wire has power, Brown does not. I've changed both switches, lights and interrupt. Any suggestions? Running a jumper to get by for now.
  3. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    have you check for a bad fuse or relay yet both the trl lights wires are on a diff fuse
  4. sbaumann14
    sbaumann14 Road Train Member
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    Try the breakers in the middle of the fuse panel....put a jumper wire on it or test light.
    Had kinda similar problem today, blinker and 4 ways stopped. Had power to ssitch on steering column, and could hear relay clicking . jumper the breaker, nope , not it. Replaced the relay....gotcha sucker! Just worn out i guess
  5. Rideandrepair
    17,548
    56,858
    Aug 8, 2015
    Is problem on trailer only? If so open up receptacle box check for a short
