96 vs 102 wide flatbed both 48ft
Discussion in 'Flatbed Trucking Forum' started by 1mm3406e, Mar 8, 2023.
  1. 1mm3406e
    1mm3406e Bobtail Member
    28
    13
    Jul 13, 2019
    Hi guys
    Is a 96 wide flatbed a dealbreaker or a 102 is a must.Which one should I be going for?Would love to here your comments.thanks
    Kyle G. Thanks this.
  3. Diesel Dave
    9,651
    32,633
    Jan 20, 2010
    Hesperia, Ca.
  4. Cat sdp
    Cat sdp . .
    21,298
    76,142
    Apr 8, 2012
    Orion's Belt
  5. JoeTruck
    JoeTruck Heavy Load Member
    853
    3,393
    Mar 13, 2015
    LOWER 48
    Bigger is better.
    Bean Jr., Kyle G. and ducnut Thank this.
  6. FLHT
    FLHT Road Train Member
    1,429
    2,546
    Aug 2, 2014
    102 Wide but only 48 long
    53 they want to load the whole yard on you .
    Blue jeans, Bean Jr., Kyle G. and 2 others Thank this.
  7. beastr123
    beastr123 Road Train Member
    2,951
    24,201
    Jan 2, 2014
    Moose Jaw SK CAN
    Depends on your freight.
    Coils and steel : 96 can be better or at least as good as a 102 but a bit lighter.
    Lumber and structural steel: 102 is better but not essential, weight is still a factor.
    Machinery: 102 is best.
    Kyle G. and 1mm3406e Thank this.
  8. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    I went from a 96” to 102”. The extra width makes all your building material loads easier. Also, for wide coils, the extra width helps with securement options. It doesn’t seem like much, but, it makes a difference.
    Bean Jr., Kyle G. and 1mm3406e Thank this.
  9. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    I would only go 102”. Two loads in the past 2 weeks specifically required a 102” wide trailer from the broker.
  10. dumptruck89
    dumptruck89 Light Load Member
    79
    106
    Feb 27, 2015
    MA
    Definitely grab the 102. There is some stuff that they won't load on a 96. Bagged materials usually need the wider trailer. If your only doing lumber and block loads you can get by with a 96.
  11. Ruthless
    Ruthless Road Train Member
    9,173
    91,066
    Aug 28, 2010
    The City.
    What are you gonna do with it?
    Bean Jr., Kyle G., cke and 1 other person Thank this.
