96 w900 431 code
Discussion in 'Kenworth Forum' started by Flatglass, Mar 16, 2023.
  1. Flatglass
    Flatglass Bobtail Member
    6
    Apr 6, 2022
    Colorado
    N14. Currently trying to chase down 431 code. Intermittent 432 code and idle only. New ECM have tried 2 TPS. Ran new wires directly to pins 6,9,10 on the ecm connector from the foot feed and still getting this code. Jakes also quit working after I bypassed the factory harness and will not come back if I plug factory pins in.
  3. Ridgeline
    22,720
    123,238
    Did you have the accerator pedel calibrated when you replaced the ECM?
    The two codes relate to this problem on the N14.
    Bean Jr. Thanks this.
  4. Flatglass
    6
    Apr 6, 2022
    Colorado
    Yes
  5. JB7
    JB7 Road Train Member
    1,008
    1,781
    Dec 13, 2022
    Laurel, MD
    The idle validation switch is used by the electronic control module (ECM) to indicate when the accelerator pedal or lever is released (on-idle) or depressed (off-idle). The switch is adjusted at the factory to switch from on-idle to off-idle at the correct accelerator pedal or lever position.
    Voltage detected simultaneously on both the idle validation off-idle and idle signal pins 6 and 9 of the OEM harness connector or no voltage detected at either pin.
    Check for 5v at Pin 10 with key on and at the pedal. Check 6 and 9 w/o depressing the pedal and with depressing the pedal at both the ECM and the pedal.
    With keyswitch on, with key switch in on position engine off, gradually push accel pedal to floor and release..do this 3 times..this procedure will recalibrate the ecm and accel pedal..if this is not your problem, inspect wires plugged into pedal, make sure they are tight, free of corrosion...same to bulkhead pass through connector..
    This code is usually caused by a loose wire connection-an accel pedal that is not calibrated, or an idle validation switch that is not wired correctly,
    Pin 10 on ecm oem harness connector will be your 5 volt supply to sensor, pin 6 is your idle signal back to ecm, pin 9 will be your off idle signal.
    Jakes quit working. May have blown a fuse.
    FAULT CODE 431 (ISS) - Diesel Engine Troubleshooting (dieselmotors.info)
    Vampire and QUALITYTRUCK Thank this.
